Page 2 of 2 FirstFirst 12
Results 26 to 45 of 45
    It took me a bit but I got the driver side frame rail screwed in! Before I weld them in I'll bolt on the k-member and triple check all my measurements. Once I get that done and rebuild the lower portion of the strut tower I'll move onto the handful of small spots on the floorboard.
    Name:  New Driver Side Rail.jpg
    Name:  Both New Rails 1.jpg
  3. #28
    I bolted in my K-member and checked the measurements. Broke out the laser level and checked my rails from side to side, front to back. I closed my garage door so the laser showed up in the pictures better. It's hard to hold the tape straight and trying to click a pic...LOL! Everything measured what it did before tore it all out so I'll be doing all of my spot welds and then fabricating the strut tower pieces.
    Name:  Laser Middle.jpg
    Name:  Laser Right.jpg
    Name:  Laser Cowl Center.jpg
  4. #29
    A couple more pics of laser. When I set the laser up for measuring I marked the floor where the feet were so it was pretty quick and easy to put it back in the same spot. I left the laser on the tripod and set it in the back of my garage so all I had to do was match the feet to the floor and make minor adjustments.
    Name:  Laser Floor.jpg
  5. #30
    qikgts's Avatar
    "Fab"tastic job right there! Loving the progress!
  6. #31
    Jul 2004
    Montebello, CA
    measure 2 times cut once
    Past 4 eyes-
    U.S. NAVY 1980-2009
  7. #32
    looks like the old girl will be set to dance again very soon.
    I'm always amazed at the ways and the scale of the rust you can find on these cars.
  8. #33
    Well I got the passenger side tower and frame rail pretty much done. Where I had the slight gap between the rail and fabricated tower lower section I just ran some self-tapping screws and and pulled them to within about 1/8" and I welded across the gap. I also welded a gap between the small piece of sheet metal to close the hole on the side of the tower to the frame rail. I dressed it all to make it look nicer. Here are a couple pics. Onto finishing the driver side strut tower!
    Name:  Finished PS Tower 2 Before 2.jpg
    Name:  Finished PS Tower 2 Before.jpg
    Name:  Finished PS Tower 1.jpg
  9. #34
    Well I got the driver side tower pretty much done, only one small plate left where the frame cap meets the tower. I'll fab that up dress it all nice and hit it with primer. Anyone have any experience with seam sealer?
    Name:  DS Tower Plate 1.jpg
    Name:  DS Tower Plate 2.jpg
    Name:  DS Tower Welded.jpg
    Name:  DS Tower Dressed.jpg
    Name:  DS Tower Dressed 1.jpg
  10. #35
    Well, I've got the rails in, towers fixed, and a little prime & paint. I should have waited to sand all the engine bay before painting but like a kid I just had to get a look with some paint. I've got the wheel wells black and the bay will be silver with black K-member but I'm wondering if I should paint the wheel wells silver too. I also cleaned and sanded the k-member and sprayed it.
    Name:  K Frame Painted 1.jpg
    Name:  DS Fenderwell Black.jpg
    Name:  PS Fenderwell Black.jpg
    Name:  PS Bay Primer.jpg
    Name:  PS Bay Silver.jpg
  11. #36
  12. #37
    Nice work and nice mig welding! Should be plenty strong when you are finished!
    Kenny
  13. #38
    Portland Oregon
    Looks real nice compared to what you started with. Just one question, you going to replace the sway bar brackets before you paint it? Maybe I missed one of your posts.....
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
  14. #39
    Yeah, I welded on the inside and outside of each plate so when I smoothed the engine bay welds it still has solid welds. Thanks!
    Quote Originally Posted by mudgepondexpress View Post
    Kenny
  15. #40
    Yep! I missed putting those on in all the kid like excitement seeing it come together and getting some paint on it. I'll just remove the paint in the lines I'll be welding to help keep the rust potential down and re-spray those. Thanks!
    Quote Originally Posted by Tigger View Post
  16. #41
    Core support sanded, cleaned, primed and painted. Not 100% perfect but I'm good with it!
    Name:  Bay Complete Paint 1.jpg
    Name:  Bay Complete Paint 2.jpg
    Name:  Bay Complete Paint 3.jpg
    Name:  Bay Complete Paint 4.jpg
  17. #42
    Jan 2005
    Cordova, TN
    Nice work so far!
  18. #43
    Nice work so far!
    Thanks Droopie!
    Well I'm waiting on struts for the front before I can install the front suspension so I figured I'd get on the rear floor where I had saw "a bit" of rust. I had to cut out a bit more than I thought and I'll have to do this to both sides. One positive is the sound deadening in the hatch area came off easily and it's pretty dang clean!
    P.S. If anyone has some 85 front sway bar bushing brackets I need them! Shoot me a PM! Thanks!
    Name:  PS Rear Rust.jpg
    Name:  PS Rear Rust 2.jpg
    Name:  PS Rear Cut Out 1.jpg
    Name:  PS Trunk No Deadening.jpg
  19. #44
    Default Front Suspension
    Got the front suspension bolted in and ready for some new rotors. I bought new a-arms, SVE lowering springs, isolators, SVE caster / camber plates but I refurbished the factory spindles and a-arm and steering rack bolts / nuts. Those turned out nice.
    Name:  DS Camber Caster.jpg
    Name:  PS Camber Caster.jpg
    Name:  Refurbished Suspension and Rack Bolts.jpg
    Name:  DS Suspension 2.jpg
    Name:  Front Suspension Both Sides.jpg
  20. #45
    Not a lot of progress in the past few months with life going on! Here's the steering rack mounted, bump kit and rotors.
    Name:  Steering Rack Installed 1.jpg
    Name:  Steering Rack Installed 2.jpg
    Name:  Steering Rack Tie Rod PS.jpg
    Name:  Steering Rack Rotor DS.jpg
