Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
  1. #26
    Barboursville, WV
    I just realized that the cheap HF hvlp gun (the purple one) only uses 6 cfm at 40 psi. There are plenty of youtube videos on it. I believe the current price is around $13.00. One of the complaints is that it isn't really serviceable. But at $13, who cares. What made me bring this up was a video I watched last night on YouTube. The channel was "Uncle Tony's Garage" and he used the cheap HF purple gun with, I believe, a 30 gallon compressor. He actually ended up painting 2 cars in two different episodes.
    UTG is now my favorite YouTube channel. It's mostly Mopar related, but interestingly enough, he has a VERY interesting history with early efi fox mustangs. He put out a 1.5 hour episode talking about his involvement in racing his new stock 87LX, along with a couple buddies and their efi foxes back in 87-88.
    https://youtu.be/bNMH3cLMp7g
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
  2. #27
    Barboursville, WV
    I apologize. The video I posted above is good, but he's using an older Harbor Freight gun. He replaced it with the newer version for the next one.
    https://youtu.be/DXQQIGCU-4Y
    I'll leave the previous video posted above because it shows a very good example of what a novice DIY'r goes through.
  3. #28
    I used a neiko gun, it did well. You cannot tuName:  IMG_20210331_35222.jpg
Size:  101.5 KBrn it upside down, that's the big limitation. I have a cheap 21 gallon kobalt, turned all the way up at compressor and down at the gun. It did fine. The pain viscosity I do believe matters as well, and the compressor did have the cfm,
  4. #29
    Wanna blow a lot of paint on quickly?
    https://www.thedrive.com/news/33651/...-terrible-idea
  5. #30
    Aug 2004
    California
    Don't use my upright 150 psi, 6 HP, 30 gal for painting. But that CFM limit also applies to air tools. If the tool's CFM consumption exceeds the CFM output of the compressor, the oil-less ones can't keep up and start to get hot. Any air-tool you buy be sure it fits the compressor output. In my experience, more expensive tools use less air; cheaper ones use more. I've been using my oil-less Craftsman for well over 15 years now.
