Results 1 to 7 of 7
    Mar 2003
    Lowell, Oregon
    Default Bolt size for wheel cylinders
    Thought I saved the old ones, but didn't.
    Bolts to hold the rear wheel cylinders on- are they 1/4-20 x1? It is an 8.8.
    Once I get them I can put the rear brake line on the axle assembly and bolt it in. Hello roller!
    Flange bolt 5/16-18 threads that are 1/2" long?
    Mar 2003
    Lowell, Oregon
    That sounds more right than my guess. I could always take the cylinder to town I guess.
    Thanks! Maybe I will grab a few of those on the way home just in n case. Save me 35 miles of driving.
    I am not 100%, but the mounting bolts are not very big, I believe the 1/4x20 size may be correct. I seem to remember the bolts require a 7/16" socket/box end to remove which would normally be 1/4" bolt. If nothing else, grab a couple of each and you should be covered....... Unless they're metric!
    Mar 2003
    Lowell, Oregon
    They're 1/2-20. Crud. Looks like I will stop again on the way home from work tomorrow. Oh well. I got a bunch, but they're too long.
    WOW! I would not have guessed that!
    Then again I don't see how they are 1/2-20, but . . . .
    Mar 2003
    Lowell, Oregon
    1/4-20!! Oops, mis type!
    But, they are 1/2" long.
