Results 1 to 3 of 3
    Default Ground cable routing on a 85
    Where did the factory attach the ground lug in the middle of the cable on a carbureted 5.0? My cable was attached to the radiator support next to the battery between it and the radiator, but I think it is the wrong spot because the routing goes in front of the battery along the frame rail. It seems a little tight.
    I
    searched and found this thread:
    It shows the cable going behind the battery but where is the lug attached?
    Thanks,
    85 GT - owned since 87
    qikgts's Avatar
    This may help although it's only a "diagram" and not an actual pic. G116 in that diagram.
    http://vb.foureyedpride.com/showthre...=1#post1738701
    When I replaced my stock '85 cable I removed the original G116 body ground lug and transferred it to the replacement cable.
    Thank you. That looks a lot better than the way it is routed now.
