Results 1 to 2 of 2
    Default Size of fittings for transmission lines into radiator
    I am looking to find out the size of the fittings that go into the radiator for the automatic transmission. Need to know the size that goes into radiator and the size that goes into the trans lines. Want to get fittings so I can plug the tranny lines and plug the radiator openings for tranny, so I can pull the radiator in my parents 42000 mile 93 GT to have it recorred, as its starting to leak. Have done this before with 1967 Mustangs but was thinking this is probably metric due to being newer car but maybe not. Any help would be greatly appreciated. Thanks.
    Jul 2010
    Houston (Clear Lake), Texas
    I somewhat went through this on my 2000 F350 when adding the OTW cooler and a larger OTA cooler. I looked for days at hydraulic supply shops to no avail. Then I finally found one that Dorman makes and was able to purchase at the local Advanced Auto. I went to the Dorman website and typed in your information...I'm seeing now your looking for a 93 GT and I typed in 91 Mustang, but it should be the same. They tell you the thread sizes here: https://www.dormanproducts.com/gsear...%2520Connector
    HAD
    HAVE
