New User
4 eye problems
Whever I turn my headlights on, the high beams will be very dim. When I turn the high beams on the low beams are very dim. The only time lights are bright is when I hold down the high beam lever. I have checked my wiring and grounds multiple times and everything is supposed to be where it is according to the diagrams. Could this be a switch issue of some sort?
- You may not post replies
- You may not edit your posts
Forum Rules
