    Default Center console connector
    Ok guys working on my 86 GT. Just redid center console and have 2 plugs that I can’t find a home for . The first one is a 90 degree boot style plug and the other is a spade connector. The low fuel light is on in info center and I have half a tank so maybe something to do with that. Any info is appreciated.
    Portland Oregon
    Looks like the lighter plugs to me. Round boot goes on the stud on the back of the lighter socket. Spade goes on the side of the socket. The socket should have a tang for it.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    Dec 2006
    Middletown, DE
    Correct^
    Make sure your battery is disconnected before you try to connect those wires. It's easy to ground out the circuit the wrong way and fry a fuse in the process. I know, I did it.
    85 Mustang GT
    Ahh ok . Forgot all about it . Thanks . Here is refreshed console. I’m back in a fox after about 10 years.
    Dec 2006
    Middletown, DE
    Very nice. What steps did you take to prep it for paint? What paint did you use?
    85 Mustang GT
