Results 1 to 8 of 8
    Jul 2004
    Miramichi, N.B canada
    Default Sending unit and spark plug questions
    Does anyone have a picture or a link to a fuel sending unit for a 1985 mustang gt? Carburetor and T5
    Also what does everyone use for spark plugs? Autolites or motorcraft?
    Dec 2006
    Greensboro, NC
    I've used NGK V-Power for the last 25 years. Inexpensive and they work excellent.
    https://lmr.com/item/LRS-9275A/Musta...ing-Unit-83-86
    https://www.rockauto.com/en/catalog/...ding+unit,4436
    My photo website:
    http://www.twilightphoto.com/
    Picture of my factory-carbed 85 GT fuel pick-up/sending unit:
    Thomas
    Jan 2003
    lansing, mi
    I used to use Motorcraft and Autolite plugs, but switched to NGK because their performance seemed to taper off pretty quickly. I haven't noticed this with the NGK plugs, service intervals have been a lot longer. All I will use now are NGK plugs, even in my lawn equipment. Seems that all anyone wants to sell for that lawn stuff is Champion junk, and those plugs won't fire after sitting a winter most of the time.
    Cale
    Jul 2004
    Thanks alot
    Have a part number or model number for the NGK plugs?
    Mar 2003
    Lowell, Oregon
    Any reputable auto parts store will have the as cross reference.
    Jan 2003
    lansing, mi
    NGK 6630 UR4
    Cale
