What are the options for getting a working speedometer when running a tr3650 and dash cluster with cable drive speedo?
You in the Portland area?
If push comes to shove (i.e. no thorough response here), these guys can probably help:
https://www.speedometerserviceportland.com/
There are a couple of aftermarket options if you want to keep your mechanical speedo. Neither are particularly cheap.
http://www.abbott-tach.com/Cable%20X.html
https://www.speedhut.com/Speedbox.html
'97 Thunderbird
I was going to use something like this for my mod swap, but I will be using 4r70w, not 3650
https://transmissioncenter.net/shop/...ruise-control/
That looks like a mechanical speedo cable setup that also gives you a VSS signal. He doesn't have any provisions on his trans to drive the mechanical speedo.
'97 Thunderbird
