Results 1 to 21 of 21
    Default Carb intake opinions
    Hi folks. I bought an 85 GT 5sp a few months ago with 62k miles, mostly stock,original except for a few goodies under the hood. I did get all the original stuff with it. It has trickflow 170 heads, stage 1 cam, Edelbrock performer 302 intake, demon 625 carb, and full dual exhaust.
    Now my question is, is the Edelbrock performer 302 intake ok with this setup, or am I leaving some on the table with it? I had it off to replace the intake gaskets, and the intake looks barely any better than stock. I know I could open the ports to match the Trick Flow heads, and I will if this intake is fine, but I'm wondering if a Edelbrock RPM or Weiland Stealth intake would be better? I don't want to buy one if it won't make a difference, so does anyone have any experience with this setup and the best intake to go with?
    Also, I've been thinking about trying a Holley Sniper EFI. Anyone have experience with one of these on our 85 and older 5.0s?
    Thanks a lot!
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Not speaking from direct experience but I'd think the Performer would be a huge restriction. Either of the intakes you mentioned would free up plenty. I'd guess 30+ ponies if the Performer is out of the box stock and you're speaking of the Trick Flow Stage 1 cam.
    Those heads could benefit from more cam too.
    Welcome to the site! Any pics of the Mustang in question?
    '85 GT
    Thanks! By looking at the Performer 302 intake, it looks marginally better than the stock intake. But I don't have any experience with the carb intakes. I've had several foxbody Mustangs through the years, but they were all 87+ EFIs.Name:  20200523_125426.jpg
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Really nice looking car!
    As it sits I'm sure those 15" tires stand no chance of hooking up! Probably makes a ton of low end tq right now.
    '85 GT
    Thanks! It's not too bad right now. Still has the stock 3:08s... when I pick up a 8.8" I'll put 3:55 or 3:73s in it.
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    That alone will wake it up a bunch! Good call!
    '85 GT
    Dec 2006
    Greensboro, NC
    Hood clearance could be your biggest issue with another intake. I ended up using the Weiand Street Warrior on my '85 convertible because I wanted to keep my hood pad insulation and didn't want it rubbing the 4V decal off the top of my air cleaner. https://www.summitracing.com/parts/wnd-8124wnd. I also can only use a 1/2in carb spacer because of the clearance problem. And, my convertible motor mounts are supposed to let the engine sit lower than non-convertible mounts.
    This is how I measured my air cleaner to hood pad clearance: Cut (2) .75in x 3in strips of cardboard from a cereal box. Bend each into a "V". Cut a vertical slit in each piece about 90% all the way through. Assemble the pieces like this: Lay one "V" on it's edge with the open part of the vertical slit facing up. Take the other"V" with the vertical slat facing down and push it down onto the "V" laying on the table. Each of the vertical slits slides onto the other piece of cardboard. Take the stacked "V"'s and place them on top of the air cleaner and close the hood. The top cardboard "V" piece will slide down on top of the other and you'll be able to measure the final height. Try it at different positions.
    My photo website:
    http://www.twilightphoto.com/
    Jul 2010
    Houston (Clear Lake), Texas
    I run the Ford Racing high rise dual plane intake manifold on my 85 GT vert and have no hood (with insulation) to air cleaner issues, and I think there's a 1" spacer in the mix. https://www.summitracing.com/parts/f...f302/make/ford It has the stock factory mount location for the coil...which I like. I have a similar setup...though your heads probably flow a bit more...and have been really happy with it. I will be fattening up the secondaries shortly and can finally see where the tell tale will fall...it pulls hard to just above 6,000 rpm when I get out of it... Very nice looking buggy you have there!
    HAD
    HAVE
    Quote Originally Posted by 854vragtop View Post
    Thanks! That's a good idea on checking clearance. Definitely want to keep the stock hood.
    Thanks! That give me hope on hood clearance.
    Jul 2010
    Quote Originally Posted by Skind View Post
    Keep in mind 854vragtop and I both have convertibles, and the vert motor mounts sit the engine down a little lower in the engine bay.
    HAD
    HAVE
    True, I'll have to see how much clearance I have first.
    Check out that recent episode of engine masters where they try several ford small block manifolds. Very interesting.
    Sep 2008
    Greenwood, IN
    What is the reason for different motor mounts in Vert's from the factory?
    Jason Smith
    MCA #65481
    '82 Capri RS Resto-Mod
    '05 S-281 Mineral Grey
    Feb 2020
    Leon County, FL
    Verts have lower center of gravity because of the lack of steel roof, so they mount th motor lower to prevent balance issues
    New User
    May 2020
    Maine (aka Canada's Florida)
    I'm running the same carb, but my heads are FMS SVO GT40's which obviously don't flow as well as yours. I have a Victor Jr. on mine with a more aggressive cam in the higher rev range. It's almost v-tech-ish. I can't say I'd recommend going with a single plane, but you are definitely leaving some horses on the table with that intake. A performer rpm or something similar would be better with your head/cam combo. It will be a huge difference when you get rid of those 3:08's as well. I switched over to an 8.8 with 4:10's, and have had 3:73's in a previous car. It makes a world of difference.
    Do the 86 verts have lower motor mounts as well? My brother has one, and he's running trick flow heads with an explorer intake.
    Thanks. I think I'll go for a rpm or a stealth. I think they are pretty similar to each other.
    Jan 2003
    lansing, mi
    I like the Professional Products Typhoon. Bigger runners than an RPM and the rear coolant crossover to help keep the intake temp from running away. Tried the Performer RPM Airgap, and went back to the Typhoon. I don't like buying Chinese stuff either, but of the two I tried it's the better intake.
    Cale
    May 2014
    Royal oak Mi
    Beautiful car
    I'm using ported stealth no insulation I had performer rpm I don't think a rpm air gap would fit but that would be my next purchase but want to keep stock hood and trying to locate factory hood insulation not the reman flat insulation.
    Stock gearset in trans with 410 is almost not enough gear my opinion I'm thinking 430 would be perfect
    With 245 50 16 at 50mph in fourth im at 2300rpm when im in fifth it's near 1400 rpm
    It idles at 900-950rpm
    245-60-15 to knock the 430down some if needed
    First mod should be gear my opinion
    Jun 2003
    Santa Maria Ca
    You’re leaving power on the table. I have a 306/AFR165/stock cam/Edelbrock performer 302 combo in an 85. Hood clearance and emission equipment are a deal here, so that’s what drove the equipment. I made 280/320 to the tire on a Mustang dyno. I use vert mounts also.
    If you like what you feel while driving, I’d just start with the gears and see how much you like that before swapping intakes.
    The aftermarket efi is pretty cool as well. I’ve got a FiTech on a 67. It’s like an efi Fox drivability wise.
    85 Saleen Mustang(s)
    Put 3:73's in my '83. Highly recommended!
