Results 1 to 10 of 10
Thread: Coil mounting
    Default Coil mounting
    How does everyone mount their coil bracket in carbed sbf?
    Tony
    Jul 2009
    Chicago, south subs
    I mounted mine to the intake manifold, driver side, front. It would probably depend on what manifold, mine has a threaded boss in that spot.Name:  P1370410.jpg
    Jul 2010
    Houston (Clear Lake), Texas
    In the stock location on the passenger side of the intake manifold...my Ford Racing intake manifold had a place for it there...
    HAD
    HAVE
    FEP Member 0F0 CBR's Avatar
    Feb 2019
    Ontario, Canada
    The early 4 cyl cars mounted it on the drivers shock tower. Only works if not running a dual snorkel air cleaner.
    Functionality? Mount it on the shock tower like shown above. Stock they sat on the intake manifold.
    The heat soak on the intake and are subjected to a lot of vibration. They live longer and supposedly work better longer on the body, not on the engine.
    Kenny
    Mine is on the firewall.
    Mine has been a few places over the years. After installing a carburetor with dual fuel feed inlets, the coil move from the intake to the fender apron. Then a recent re-fit of my dual snorkel air cleaner prompted another relocation to above the power steering pump.
    Thomas
    Dec 2006
    Greensboro, NC
    I also mounted mine just above the power steering pump when I installed my Summit carb (because of the dual feed lines).
    My photo website:
    http://www.twilightphoto.com/
    Where God intended Pass side under the stock air cleaner on the manifold. Why anywhere else? Its a Ford 302 coil this is not time for Where's Waldo.. lol
    Jan 2004
    Olathe, Kansas
    Kenny
    This is what I think and did also.
    Now stang-less.
    88 Cougar 5.0
