Results 1 to 6 of 6
    Default Fuel door release not working
    I am new to the Mustang world. Just bought an 85 LX 5.0 convertible. It is low mileage and in very nice shape but had a few electrical problems. I sorted through them and the only thing left is the fuel door release.
    I have no power to the switch and don't know what fuse it runs through.
    also the fog lights don't work and I see now switch for them.
    Dec 2006
    Middletown, DE
    Not sure if the fuel filler door has a relay or not. I can check later if someone else doesn't chime in first on that one. The fog light switch (if they are factory fog lights) is on the lower dash near where your left knee would be if you were sitting in the driver''s seat. If they are non-factory fog lights, which I believe they are since LX's were not available with factory fog lights (only GT's), who knows where the switch might be?
    85 Mustang GT
    I will have to trace back the wires. There is a spot under the dash where you mentioned that had something fastened to it.
    Found the problem with the fuel door. Fuse was missing.
    Whitestone, NY
    What fog lights come on a LX mustang?
    Someone added the fog lights. They aren't even wired up.
