Results 1 to 2 of 2
Thread: Running Rich
    Aug 2011
    Clarksville, AR
    Default Running Rich
    84 Ltd lx 5.0 sefi, t5, 8.8.
    The engine starts on the first turn cold, idles a little high, runs good. When it is idling it is running rich, if it sits and idles for 2 minutes the fumes will run you out of the car port.
    Jan 2003
    lansing, mi
    Is your fuel pressure regulator hooked up correctly? Is the diaphragm in good shape and working as it should with vacuum applied? What injectors are in it?
    Cale
