Hey folks! I'm currently in the process of completing my 1g to 3g conversion on my 85 gt. formally a CFI car that was missing most of its wiring when I bought it, so i dont have much of a reference here. I'm doing the swap using the pa performance kit so I can keep the dummy light working in the dash. I'm mostly done the swap but have a few questions. first this orange/blue wire that I found dangling about that leads to the "f" terminal on the new external regulator (it was in the same loom as the black/orange wire going to the 1g alt). This is what I believe to be the field wire and should connect to the green wire on the 3g harness, I'm I correct on this? second, this green/red wire connects to the "s" terminal on the external regulator and seems to lead to another connector that doesn't plug into anything. I'm assuming I'm missing some of the wiring here or that it's for the original CFI harness. What should this wire connect to and what does it do? Do I leave it alone and unplugged? I might be beating a dead horse here but I can't seem to find what I'm looking for online any help is appreciated. Thank you!
