Results 1 to 4 of 4
    Default SFC sunroof restore questions
    Bought my 86 gt a few months back and I’m finally getting to do some upgrades. Already purchased the door seals and the hatch seal, but I’m needing to replace the sunroof seal as well. I’m doing this more as preventative maintenance so it doesn’t leak in the future (no leaks noticed currently) only place I’ve found with the parts is DK hardware and I measured it so I know it’s the 15x30 glass. I’ve found the seal but what what should I get for it?
    I am guessing this is not an OEM sunroof, as I have not seen trim that looks like what your picture shows. Unfortunately I don't believe any of the regular Mustang vendors will show weatherstripping or seals for your specific sun roof. There were tons of companies back then that offered aftermarket installs of sunroofs and so many of them have closed, been sold off, etc. If your seals are currently doing the job, I would leave them alone and not mess with them.
    If the vendor you have found has the seals/weatherstripping for your brand and model, then I would just buy them as back up when they are needed. Good Luck!
    A quick search shows the SFC Sunroofs are one of the aftermarket companies which you can get parts for. Sun Roof Dr.
    I’ll have to look them up. My biggest question would be do I only replace the seal or is there usually another part like the trim ring or anything else that would be good to update on it?
