Hello,
My car was a 6cyl automatic. I was wanting to keep the column shifter for my 4r70w, but instead of the shifter cable going to the column like the cable that is in the trans now, the Zephyr has long shifter shaft that runs parallel to steering shaft. Also the linkage seems to be mounted to the K member. My car came with no shift linkage or cable so I知 just guessing lol
i have a tubular K member, so nowhere to mount stock linkage.
Has anyone ever found a way to make this work? Or am I better off going with a floor shifter? Is it easy to remove the shift lever from the column? It looks like it would be a pain in the ass.
Thanks for any info/advice
