I’m trying to help a friend with his foxbody from afar
He took a great running stock 91 LX notchback with barely over 100K miles on it apart to freshen the engine up, reseal everything, and do some upgrades.
well - it has went WAY less than stellar to put it mildly. The engine has been completely apart and back in the car and apart again and back in and part yet again and back in ..... and apart still again
The block was tanked and magnifluxed and everything checked out good. all the threads were chased with a properly sized tap, and cleaned of any possible debris. All of the passages were blown out too. It received a hone and a second cleaning and blow out followed by new cam bearings and freeze plugs. Etc
the rotating assembly received new stock rings and bearings and everything was put back where it had been. All good there
The crank simply received a cleaning and polish - it’s good too
The engine received an E303 cam. Why the hell an E cam ..... Lordy don’t get me started ..... but that was what he picked. His car so he can lose all the area under the curve he wants to. And if he wants to get left sitting by my 86 as-is that’s his business too!
Anyway .... bottom end went together with new ARP fasteners and Felpro gaskets
Ford Racing roller lifters were sourced. A set of “Freshly Rebuilt” GT40 heads and a Cobra intake were acquired.
Yep — you know where this one was going when you started reading
Assembled the damn thing and fired it up and it ran like dog ****. Just absolutely wouldn’t get out of its own way and smoked too.
Hours of diagnostics and wiring testing, etc, later he knew cyl 1-3 and also 6 were WAY down on exhaust manifold temps. They were dead holes.
Tore it back apart and the culprit was determined to be bad exhaust valves on 4 of 8 cylinders. Rebuilt with what, bad parts?!
Back together it goes. Fires it up. It’s running pretty decent overall but after just a few short drives it is clear it is using oil like a freshly stuck pig bleeds. what the f. Never did before it was tore down initially.
Before tearing into it, might as well see what else is going on. Compression is good on all 8 holes but #1 has traces of antifreeze on the plug. Fire it and sure enough it’s down several degrees on exhaust temps. Antifreeze is MIA from the overflow and radiator
Tore it out and all the way back out. Found absolutely nothing that would explain the oil consumption. Nothing that would explain the missing coolant either.
head gaskets and intake gaskets looked as expected before tear down - no tell tale that either had failed to seal. No evidence of oil in the antifreeze or antifreeze in the oil.
I did some reading and found references to the Chinese Ford Racing intakes having problems with sucking oil in the PCV due to a faulty oil shield. It is the Chinese version. PCV valve confirmed it. Upper seems good. The lower seems to suck for multiple reasons like the oil problems, clearance by the distributor, etc. but now we’re getting somewhere
Took the heads and block in to get them rechecked - specifically looking for cracks. We were just sure that had to be something amiss here. It wasn’t
So nothing to reasonably explain the coolant traces getting into #1
I did some reading last night and found mention of some faulty casting on some of the cobras allowing coolant between the crossover and #1. Even had pictures of the faulty area. Be damned if I can find it now.
Where I’m at is make sure the heads decks and block are straight and true because it’s apart and that’s what you do
Figure out a way to pressure test the coolant passage while putting vacuum on the #1 port without putting that intake back on the motor. Confirm it’s junk or if it’s not measure the lower and make sure it’s square and straight..... strongly consider ****-canning it anyway
Head to the scrap yard after a 96-97 Explorer or Mountaineer lower to clean and polish and prep for the motor and end this insanity
Any thoughts by anyone here that might help this cause. This damn car has been repeatedly pulled and torn apart and taking up space in his garage since December now. No idea how many hundreds of hours are in the crapper on this damn thing
