    Apr 2009
    Acworth, GA
    Default 85+ steering rack sleeves in 84 K Member
    Hi,
    I'm assuming I need to drill a larger hole for the 85+ steering rack sleeves to fit in my 84 K Member right? If so, what size hole?
    I think the smaller end goes into the K Member since the bushings are tight on the larger end but want to be sure I drill the right size hole.
    Chris
    Jan 2003
    lansing, mi
    The 79-84 use larger bolts than the 85+. 79-84 are M14, 85+ are M12.
    Cale
    Jan 2016
    South Central Ohio
    My 85 that was built 10/84 had the larger bolts.
    Quote Originally Posted by cb84capri View Post
    Cale
    thank you for this info!
    Apr 2009
    Acworth, GA
    I opened the front holes to 3/4" and the sleeves fit tight. Ran out of daylight to get the rack torqued down but that seems to be tight enough.
