Results 1 to 7 of 7
    Default Rear Control Arms
    I got these on the bay today for $50 to my door.
    They are made by MAC and look to be stronger then junk
    ones made in china
    Has anyone used MAC before?
    Thanks,
    ed
    New User
    Nov 2006
    Glen Williams Ontario
    yes I've had them on my car for several years. very happy with them order, Hotchkis replacement bushings for them, since Mac no longer sells them.
    Jul 2009
    Cherryville n.c.
    I had a set of them on my car for like 4 years and the rubber fell out the lowers. took a while to find out why it was driving funny.
    Nov 2004
    Chas. SC
    I only run the lowers. Took all the wheel hop out and installation was a breeze.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Thanks All,
    Ed
    The bushings are pretty much only good for stock daily drivers. Any spirited or track use and they split and deform in short order. You get what you pay for.
    I ended up going with BBK bushings.
    ed
