Results 1 to 10 of 10
    Default 94/95 SN95 Spindles
    Are all 94/95 Spindles the same?
    Thanks,
    ed
    I believe you as asking V6 or V8? Yes they are the same. Brakes are the same also.
    Kenny
    so stock 94/95 spindles are the same as SN95 units
    All 94/95 spindles are the same, V6/GT/Cobra all use the same spindle. This is true for the 96-04 spindles also.
    Brakes are the same for V6 and GT. Cobra brakes are different and allow for the larger rotors due to different caliper cradles front and rear.
    THANKS, THANKS, THANKS.
    ed
    Mar 2013
    Where the Navy sends me...
    Quote Originally Posted by ThunderStruck View Post
    '94/95 spindles *are* SN95 units, so I'm not sure what you're asking.
    '96-04 spindles are also SN95 units, but they are not the same as '94/95 spindles.
    isn’t it the ABS tone rings that are the difference between the 2?
    The 94/95 spindles have a curved steering arm. The 96-04 have a straight steering arm. The change was necessitated by the swap to the 4.6 in 1996 and the engine having to sit lower in the K member. Using 96-04 spindles on a Fox with an OEM K member will cause bump steer that can not be fixed even with a bump steer kit.
    Courtesy Maximum Motorsports
    thanks so much for the Info! Much appreciated
    If you replace the hubs.. It really doesn't matter if you buy replacement hubs with or without the ABS ring. Either works fine.
