Results 1 to 25 of 30
    Default Refinishing GT dash bezels (inserts) '84 GT
    EDIT: See post #10 for what ended up happening.
    Not finding anything searching the site other than suggestions on finding better replacements.
    I have my dash out of the car and dyed everything. My bezels are looking a little worse for wear. I grabbed an extra cluster bezel a few years ago, and as others have noted, the grey is way off from my originals. I really don't want to put in mismatching pieces. Here's a few pics of what I'm working with below.
    Has anyone successfully repainted the grey in their GT dash bezels? If so what paint did you use? I'd like to keep the finish as close to stock as possible. Lots of taping off and the faux screw heads might be tricky. Any tips or advice welcome. Thanks!
    86 LX Coupe
    Any idea if these would come close to the grey these panels were originally?
    https://www.npdlink.com/product/inte...1984&year=1984
    https://www.npdlink.com/product/3915...1984&year=1984
    Dec 2006
    Middletown, DE
    Personally I think those two grays are going to be darker than what you are looking for to refinish the bezels. You could always buy a can of each and do a test shot on an unwanted piece of plastic to see how they turn out.
    There are some other options. You might want to try and find a paint store near you that will mix paint in aerosol cans. They may be able to mix you some pant that is close to the original color. You could also visit a local hobby store and look for a model spray paint that is close to the gray color.
    85 Mustang GT
    Quote Originally Posted by tbirdman View Post
    Good idea. Once they open things back up around here a trip to the hobby store is in order.
    thanks tbirdman. Don't set the building on fire.
    The issue I had when trying to refinish the GT bezels was that the grey is a coating or film and not a regular paint. Getting the same slick surface and look is difficult using any standard spray paint or even automotive paint.
    Although probably a more expensive option, I would look into have the parts hydro-dipped rather than trying to paint them. May not be in your budget, but I would at least consider it. If the price isn't too crazy I think the results will be more like the OEM finish than most attempts using spray paint. That's my .02 for what it's worth. Good Luck!
    Maybe vinyl wrap? Defiantly would come out smooth. Inexpensive. Many options of look and brands.
    Reversible no damage. Peel and stick. Couple of 3" x 5" samples would cover.
    https://www.metrorestyling.com/ORACA...ir-s/18743.htm
    Thanks, Trey & gr79. Researching options. Appreciate the feedback.
    Dec 2006
    Middletown, DE
    Here is one member's thread from a ways back on refinishing the dash bezels...
    http://vb.foureyedpride.com/showthre...ght=instrument
    85 Mustang GT
    You're the man! I mean, you're the tbirdman!
    Thanks for digging that up. I need a lesson in searching. lol
    After a lot of thought, pulled the trigger and used some nice brushed aluminum vinyl. Wasn't looking forward to taping off every little detail (especially all the fake Allen screw heads) & attempting paint. Amazon had some in a color similar the the factory grey. Lighting makes all the difference... In low light it looks pretty close to the factory grey. In sunlight it really pops. Still need to do the piece above the glove box. Had to repaint the black border on it as it had some overspray from the PO's terrible attempt to dye the red dash black.
    vinyl: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    What do y'all think?
    86 LX Coupe
    The dash panel looks Great! Congrats, I should have recommended that in my earlier post, but apparently wasn't thinking. I did the same thing years ago when the carbon fiber "look" was all the rage and vinyl wraps were just coming into their own. Not bad at the time, but definitely not my taste theses days.
    Thanks, Trey!
    Yeah, that carbon-fiber look sure has made the rounds. Looks better in some cars than others. I've always had the mentality "it's your car. Do whatever you like!"
    Hope your dad is doing better.
    Kent
    Dec 2002
    New Boston, MI
    I like it.
    Might consider doing something similar. A carbon fiber would look good too.
    Dec 2006
    Middletown, DE
    Very nice!
    85 Mustang GT
    Quote Originally Posted by graphicdesigner80 View Post
    Thanks, Trey!
    Kent
    Thanks! Dad is doing better and that is great! The carbon fiber I used was one of the original vinyl versions that today looks very fake and unrealistic. I have some of the new carbon fiber that is very real looking and probably would look really good if I choose to go that route, but not sure that is what I want at this point in my life. Today's vinyls are really cool and impressive in how realistic they can look and pretty easy to work with.
    Very nice!
    Thanks, tbirdman!
    Very good news! Hope things keep going well for him and he can get back home soon.
    It's amazing what they can do with vinyl these days. Some of that stuff out there is crazy-intricate. Looks like the sky's the limit, as long as you got the money Are all your cars in CO?
    I'll get some pics once the dash gets put back together. Will be nice to actually have a complete interior for once.
    Jul 2004
    Montebello, CA
    wow it looks great! but I was going to suggest flocking like the svo dash
    Past 4 eyes-
    U.S. NAVY 1980-2009
    Those always looked cool to me. I’d always be worried about the kids touching it and rubbing it off
    86 LX Coupe
    FEP Senior Member ddx77's Avatar
    Jul 2011
    Fort Lauderdale, FL
    You mind me asking how you got the edges so perfect, and the holes? Looks amazing!
    Quote Originally Posted by ddx77 View Post
    Thanks Drew.
    I spent about 3 hours with an exacto knife... most of that time was on those dang Allen heads. Roughly cut out the shape needed to cover a section then went to town. Stuff is very forgiving and easy to pull off and try again if you mess up. It's not perfect, but given what the rest of my junker looks like, it's an improvement.
    Whitestone, NY
    Very nice results.
    Thanks! No not all of my cars are in Colorado. I kept buying cars when I was remodeling my parents house there in Round Rock. My 82 RS, my 81 Black Magic, and an 89 GT roller are still there at our old shop out in Hutto. The RS I was restoring at night and some weekends while I was down there just to keep my sanity. The BM is a basket case, but I seem to really love the diamonds in a rough. The GT was a parts vehicle purchase. We will have to try and meet up the next time I am down there.
    Wow. Awesome collection. Be fun to check them out sometime. Hutto has gone from a one-stoplight town to suburbia in the past 10 years.
    I’m right down the road behind the Dell Diamond.
    86 LX Coupe
    There is nothing awesome about the collection! All of my cars are diamond in the roughs or basket cases that most wouldn't buy as a parts car. The 82 RS was a rust bucket from Smithville that I bought from the second owner that had is sitting for over 20 years. I couldn't let it die, so I have rebuilt/repaired most of it and ultimately it will be repaired to a like original look exterior/interior wise with a bit more power and Aero brakes.
    The BM is a T-Top car too and been my "Lady in the Red Dress" trying to find for years, but just never worked out. Probably crazy to try and save it, but then again I did graduate from Round Rock High School, so . . . .
    I'll be happy to show you the mess of Foxes I have the next time I make it down there. I know we are going down in July for a wedding, but not sure what spare time I may have then. Will definitely keep you in mind. I have a HS buddy that lives in the same subdivision as you behind Dell too.
    Wow. Small world. Spare time seems to be at a premium these days. Every time i visit the folks it's the same issue - too many people, not enough time.
    There's just something about these cars that seem to attract certain folks (cool ones). Even if they're rough or junkers to a regular joe. My vert is definitely in that category. Could've been easily parted out in the shape it was when I bought it. I think it's something to do with growing up during that period and not seeing many around anymore. If I had a nickel for every 'Christine' reference thrown at me by my friends... 'ya can't polish a turd'... 'it cost you a sh**-pile of dough to put this heap together'... etc, I'd have enough money to paint the dang thing! haha.
    86 LX Coupe
