Results 1 to 4 of 4
    Default 86 capri window casing(pics)
    I was going to sell it but now im refurbishing it I need help and ideas on replacement window casings and rubber can be found or trying to fix these by painting anything helpful please
    Jul 2004
    Montebello, CA
    well the ones on the doors are the "run channel seals" sold at our part sellers, and the ones on the little windows are the black windshield seal goop
    Past 4 eyes-
    U.S. NAVY 1980-2009
    NO need to replace the trim around the windows. Just sand and refinish. Not a big deal, can be done in any garage or even the driveway on a calm day with some masking. As noted you will want new window door channel runs and the outer dew wipe seals. The new dew wipes only come with the metal trim know IIRC, but personally the new trim is crap. It doesn't fit and not the same quality as OEM. I remove the wipes from the originals, refinish them and then swap the new wipes onto the old trim. Takes a little practice to pop the wipes off, but they can be removed without damaging the trim pretty easily. Make sure to refinish the mirrors while you have them off too otherwise they will look terrible next to the new refinished trim. Same might be said for the windshield trim, cowl panel, rear window trim, and body moldings. NOW you see why all of my projects become long term restorations. Good luck!
    Dec 2002
    Greenville, SC
    Love the 86 Capri! You can make that nice!
    Here is some part information
    Dew Wipes - like 'Trey' said in the post above, use your metal not these.
    https://www.npdlink.com/product/mold.../166136/150338
    Run Channel
    https://www.npdlink.com/product/run-.../166179/151031
    You 'may' need door weather stripping??
    https://www.npdlink.com/product/weat.../166142/151031
    Trim Paint
    https://lmr.com/item/MET-EXT-01/84-8...ior-Trim-Paint
    1979 Mustang Cobra 5.0
    2P Red and 1C Black
    Stock never goes out of style
    Proverbs 3:5-6
    My Mustang Story
