Hi all,
I noticed that my power steering rack is starting to leak from the inner tie rods so I was thinking about replacing the rack with a reman one. The question I have is since I have it out maybe I would convert my power steering lines to -6AN lines. I saw that Maximum Motorsports sells adapter fittings for the rack portion but what will I need to go to a AN fitting at the power steering pump? Mine is a 1985 GT
I also think that at the same time I will replace the factory cooler line with a power steering radiator. I saw a universal 10 row on amazon that comes with AN fittings. Has anyone used one of these before with success?
Any advice would be appreciated. I tried searching for this info but havent had much luck
