    Jul 2016
    Duncannon PA
    Default Original style heater hoses
    I need to replace the heater hose on a 79 pace car. I have the original factory hoses right now and the hose from the intake fitting appears to have a molded in elbow. And the hose from the water pump fitting to the heater core appears to have a short molded hose with a splice going into common style heater hose. It all has the original style "tower" hose clamps so I'm fairly certain it's an all original setup.
    So does anyone make the correct molded hoses. I found Gates numbers but no pics to verify correctness.
    Current Mustangs
    1966 6 cylinder coupe
    1984 SVO 9W
    1985 Saleen #132
    The svo has some molded hoses with elbows, you might want the check them. Also do a google search using gates and the number to see what pictures come up.
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Can you share a couple of pictures of the originals? Our 79 302 does not have originals on it so when I get to replacing I'd like to know what I am looking for too.
    If you find a decent replacement can you let us know? I'll be in the same boat as you soon.
    Dec 2002
    Greenville, SC
    Here is a couple of 300 Mile Pace Car Engine pictures I use for reference. Hope this helps
    1979 Mustang Cobra 5.0
    2P Red and 1C Black
    Stock never goes out of style
    Proverbs 3:5-6
    My Mustang Story
    Jul 2016
    Duncannon PA
    Current Mustangs
    1984 SVO 9W
    1985 Saleen #132
