Pass frame rail, under battery. Worst spot on the car.
Guy I bought the car from was nice enough to give me a piece of frame with the car.
Donor rail is from a later fox though, and has welded on swaybar mounts instead of the bolt on brackets with internal mounting nuts.
Going to have to weld the old front and rear parts of the top of the rail to the new rail section, as the donor rail was not full length
Not going to completely cut the rail, want to retain the stock style bracket
