Results 1 to 14 of 14
    Cool 1986 Mustang HVAC control
    My '86 GT is up and running, and now we're working on the A/C system. The evaporator coil, accumulator and all lines have been replaced, leaving only the compressor and condenser coil from the original car. The system holds pressure, but we can't get the compressor to cycle automatically. Tracing thru all of the components, the dash-mounted control for the blower motor, temperature and function (heat, a/c, defrost, etc.) does not consistently make contact when in the A/C mode. Does anyone know if I have to replace the whole control unit, or is there a switch component that can be replaced?
    Jul 2009
    Cherryville n.c.
    did the 86 have the kickdown cut off for the ac like the carb cars had that cut the ac off at full throttle. I had to bypass it on my 84 when I changed the carb.
    Quote Originally Posted by liv2roc View Post
    liv2roc, I honestly don’t know. It is supposed to turn the A/C off at WOT. But the problem I have is with the function switch.
    When you say it doesn't make consistent contact in A/C mode . . . What doesn't make contact? The whole unit loses power, the unit quits working, the power to the A/C cycling switch and compressor is not consistent?
    As far as the compressor cycling, have you tried jumping the cycling switch on the accumulator? Is there power to one side when the control unit is in A/C mode and the car is running? If so and you jump the cycling switch do you get power to the A/C compressor unit pigtail? If yes, does the clutch engage and the compressor cycle?
    wraithracing, sorry I wasn’t more clear. We can jumper to get power to the compressor clutch pigtail, and the compressor clutch engages and the compressor works. But the whole process starts when I put the function switch in the A/C mode (Normal, Max A/C or Defrost). When I started, the connection thru the function switch was largely intermittent. We would get power thru the switch sometimes, but not at other times. We’ve been using contact cleaner and working the switch back and forth, and it’s gotten better; still not 100% of the time, but much improved. The system has been charged, and when charged put out air at 42F.
    My post was specifically about the function switch and whether it can be replaced separately, or does the whole control unit have to be replaced. At this point, I can probably live with it, but if the switch could be replaced, I would consider it.
    Dec 2006
    Middletown, DE
    Sorry if I'm late to the party, but you're talking about the middle selector switch on the panel that moves up and down and selects defrost, AC, Mix, etc., correct?
    85 Mustang GT
    Quote Originally Posted by tbirdman View Post
    tbirdman, yes, you are correct.
    Dec 2006
    Middletown, DE
    As far as I know, you can not just replace the lever arm. I know that there was a member here who posted on how he replaced the faceplate a while back, but the two arms, the one that selects the temperature and the one that selects the different functions, are integrated into one mechanism at the back of the control unit.
    And I'm not that electrically inclined, but I don't believe the HVAC functions are actually controlled electrically, but rather by vacuum, which is fed through a harness attached to the back of the control unit and leads to the separate blend doors. But that's just a guess on my part.
    85 Mustang GT
    Tbirdman is partially correct. The center selector lever is both vacuum and electric. As you move the lever up and down it alters the vacuum to the different dashpots that control the different blend doors to direct the air to the specified vents. As you move the lever from off to the A/C section it sends power to the A/C low pressure switch which will activate the compressor clutch if the system pressures are correct. The electrical plug for the center selector switch is at the top of the unit. Normally you can only see the sides where the pigtail connects, but in the pictures below you can see the terminals and the circuit board inside the unit that control the electrical flow.
    So to answer your question, no you can't replace the center lever/switch without replacing the whole unit. That is essentially part of the base unit and is not removable or repairable easily. Not saying it can't be taken apart, but it will take time, effort, and care not to destroy it and make it functional again. Good Luck!
    Thank you, tbirdman! ��
    Tbirdman is partially correct. The center selector lever is both vacuum and electric. As you move the lever up and down it alters the vacuum to the different dashpots that control the different blend doors to direct the air to the specified vents. As you move the lever from off to the A/C section it sends power to the A/C low pressure switch which will activate the compressor clutch if the system pressures are correct. The electrical plug for the center selector switch is at the top of the unit. Normally you can only see the sides where the pigtail connects, but in the pictures below you can see the terminals and the circuit board inside the unit that control the electrical flow. We
    Thank you, wraithracing! I suspected as much. My ‘86 GT has about 98,000 miles, but it’s spent a lot of time inside, so the dash pad, instruments and controls look really good. I guess the 12-15 years it wasn’t used caught up with me, causing sporadic performance because of lack of use. The function switch is working better, and the system has been charged with new refrigerant. When it gets hot, I might have to work the lever a bit to get it to work!
    Just like the picture shows, they break over the years and the connections get spotty. Replaced my daughter's low mileage 1983 version this winter.
    Kenny
    Kenny
    Thanks, mudgepondexpress. I guess I need to keep checking on eBay for one from an ‘85 or ‘86, just in case.
    Most likely the reason they break is the cable gets stiff. When pressure is put on it, it snaps. I looked at one a while back and thought a metal bracket could be made to make a repair. I always leave mine on defrost and heat for the winter as the heat cable frees up when warm. Lubing or replacing the cable should not be over looked. Some day we may run out of spares.
