I recently connected with someone of Facebook that has a 1979 2.8 V6 WITH manual set up. He was going to sell me the entire drivetrain for a very reasonable cost once he started his project to V8 it. I've been looking for a 2.8 manual set up for a while.
Was told last week their plan has changed and they may be looking to sell the car. I do not want to miss the opportunity for the manual set up to upgrade our other car. The rest of the car looks reasonable also.
Car is around 8-10 hours one way drive from me. Car sat for 20 years. Car looks to have been from the USA and speedo/odometer is in miles. Car is currently in Canada.
Car had been repainted. The trunk lid has been replaced with a non-79 one.
What would be a reasonable cost or offer for this car?
Date - 08-78 = August 1978 build
GVWR - 3759 lb/1705 kg = gross vehicle weight rating
Front GAWR - 1978 lb/897 kg = front gross axle weight rating
Rear GAWR - 1801 lb/816 kg = rear gross axle weight rating
F0137 = 0137 lbs front accessory reserve load
R0061 = 0061 lbs rear accessory reserve load
Exterior Paint Colors - 9D = Polar White
DSO - 23 = Memphis district sales office
Body - 66H = Mustang Ghia 2-door sedan (coupe)
VR - [blank] = no vinyl roof
Mldg - 73P = Black bodyside molding, Argent inset stripes
Int Trim - FB = cloth & vinyl seating, low-back front buckets (F), Wedgewood Blue interior trim color (B)
AC - A = manual air conditioner
R - [blank] = no factory radio
S - C = sunroof
Ax - F = 3.45:1 axle ratio, conventional (non-locking) differential
Tr - 5 = Tremec SROD 4-speed overdrive manual transmission
DD = front springs
MM = rear springs
https://s1337.photobucket.com/user/8...nfjpn.jpg.html
https://s1337.photobucket.com/user/8...uknit.jpg.html
https://s1337.photobucket.com/user/8...lmcub.jpg.html
https://s1337.photobucket.com/user/8...gfbpp.jpg.html
