Results 1 to 10 of 10
    Default Decode T-Top Coupe
    It appears to be a really low optioned car. Was wondering if the T-top is the only option on the car.
    Is there a way to tell if it came with a radio or not? Somebody chopped up the dash to put a aftermarket one in.
Size:  195.2 KBName:  IMG_E2291.jpg
    Looking to buy a 1981-84 T-Top Coupe. Any motor, transmission, or color. Let me know what you have or find!
    VIN
    1FA = Ford vehicle manufactured in USA
    B = active belts, no airbags
    P = passenger car
    10 = Mustang 2-dr sedan (coupe)
    A = 2.3L engine
    9 = VIN check digit
    B = 1981 model year
    F = Dearborn Assembly
    240009 = 140,009th 1981 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 07/81 = July 1981 build
    GVWR - 3570 lb/1619 kg = gross vehicle weight rating
    Front GAWR - 1789 lb/809 kg = front gross axle weight rating
    Rear GAWR - 1805 lb/818 kg = rear gross axle weight rating
    F0027 = 0027 lbs front accessory reserve load
    R0095 = 0095 lbs rear accessory reserve load
    Exterior Paint Colors - 27 = Bright Red
    DSO - 58 = Twin Cities district sales office
    Body - 66B = Mustang 2-door sedan (coupe)
    VR - [blank] = no vinyl roof
    Int Trim - BD = cloth & vinyl seating, high-back front buckets (B), Medium Red interior trim color (D)
    AC - [blank] = no factory air conditioner
    R - [blank] = no factory radio ?
    S - D = T-roof
    Ax - Y = 3.08:1 axle ratio, conventional (non-locking) differential
    Tr - 7 = Ford of Germany 'Hummer' 4-speed manual transmission
    CC = front springs
    FF = rear springs
    Buck Tag
    MUSTANG = Mustang model line
    66B = Mustang 2-dr sedan (coupe)
    A = non-turbocharged 2.3L engine
    TR = T-roof
    036 = body & paint rotations #036
    27 = Bright Red exterior paint color
    DF
    ST
    01 = rear glass with no rear defrost
    01 = no hood scoop
    -D = Medium Red interior trim color
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Thanks! Is the only option you see a t roof?
    Some option codes are not on either tag. Lack of a radio code on early (79-82) Capri and Mustang door tags does not necessarily mean no radio. I would need other tags and documentation for the car the get the bigger picture.
    From a lack of some codes, or specific codes that could have been different, I can tell you that the car did not have the following options.
    2.3T engine
    3.3L engine
    4.2L engine
    5-speed manual overdrive transmission
    air conditioner
    automatic transmission
    carriage roof
    cruise control
    hood scoop
    leather seating
    light group
    limited slip differential
    lower bodyside protection
    lower tu-tone paint
    mud flaps
    power lock group
    power windows
    rear defrost
    Recaro seating
    rocker panel molding
    special tu-tone paint
    sunroof
    vinyl roof
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    This is true. One of our 79's had the radio spot blank on the door tag. The initial Marti report showed a "2" in the radio spot for an AM radio. The car did actually have a factory AM radio in it when we got it. I opted to have the replica door tag from Marti not have the number in it to match the original.
    The following options did not have a code on either the door tag or buck tag.
    accent tape stripes
    appearance protection group
    console
    deluxe seat belts
    dual rear speakers
    emissions system, California or high altitude
    front floor mats, cloth or vinyl
    front licence plate bracket
    handling suspension
    heavy duty battery
    interior accent group
    interval wipers
    leather wrapped steering wheel
    luggage compartment light
    pin stripes
    power brakes
    power steering
    premium sound system
    roof mounted luggage rack
    sport option
    tilt steering wheel
    tinted glass (complete)
    tinted windshield
    tires, Michelin TRX or white sidewall
    wheel covers, turbine or wire
    wheels, cast aluminum or forged metric aluminum (TRX) or styled steel w/trim rings
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    accent tape stripes
    console
    deluxe seat belts
    dual rear speakers
    handling suspension
    heavy duty battery
    interval wipers
    pin stripes
    power brakes
    power steering
    sport option
    tilt steering wheel
    tinted windshield
    Thanks for the info! Ill print these lists off and go around the car to see what it has and doesnt have.
    If you find a build sheet it'll all be on there.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Whats the best place to look for one?
    Anywhere really. Most common places are under front carpet, under rear seat, and behind interior trim panels. But it may not have ever been left in the car. Or if it is there it may be damaged beyond being legible.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
