Results 1 to 25 of 25
    Default Muffler choice question
    I currently have the LMR american thunder X pipe and mufflers.
    I love the sound, but the drone at 1800-2000 is mind numbing,
    So I am going to swap them out.
    Question is what are good-loud mufflers that have less drone?
    I know the flowmasters are chambered and I am thinking a straight through type muffler would be better
    any suggestions would be great
    I’ve loved every Magnaflow I’ve ever heard for what it’s worth.
    My 85 cane with Flowmasters. Not sure which version as they are more than 10 years old. My guess is three chambers. They are Reasonably quiet as most of my cars are stock. Borla S is always nice.
    40 series
    love the sound of the car
    it is just unbearable inside
    St. Louis, MO.
    I have Dynomax Super Turbos on my 88 5.0. For me the drone noise at 45-50 mph in 3rd gear (AOD) is just right and will scream a bit on full throttle.
    Scotty
    Past Pony's.....
    Oct 2017
    south-central WY
    If you haven't already done so, I suggest that you read this thread before changing mufflers:
    http://vb.foureyedpride.com/showthre...one-inside-car
    The resonance inside the car can sometimes be changed by adding extra muffler/pipe hangers, weights on the pipes, or different size exhaust pipes/resonators. Stringed musical instruments, especially the cello, are subject to unwanted resonance in a similar way, called "wolf tones".
    Two thumbs up for Dynamax Super Turbos! Love mine, had them for years and it always gets compliments for sound.
    Magnaflows are a close second.
    Kenny
    I had Dynomax mufflers on my 86GT back in the 90's. They sounded great. My only complaint is that they didn't last particularly long. Around 5 years and it was time for a new cat-back kit again.
    At that point I went with a MAC cat-back. It was also a wonderful sounding exhaust, but only lasted around 10 years.
    These days I run a system thats a scabbed together combo. BBK equal shorty headers, MAC X-pipe, a pair of flowmaster 40's cobbled together with shelled out old MAC pipes.
    The combo without the tailpipes was obnoxiously loud. It is a lot better with the tail pipes but it does drone big time going down the interstate.
    It was a lot worse with the H-pipe than it is with the X, but its still bad. I am certain it is the flowmasters causing this.
    Dynomax or Magnaflow do not tend to drone. They usually have a nice burble.
    If I were to redo it, it would be H pipe with high flow cats and Magnaflow or Dynomax mufflers. More or less whats on my 85 Saleen clone we are in the process of trying to find time to finish.
    Can't wait until its time for my 86 to get blown apart finally after all of these years.
    I like my Dynomax Ultra Flo welded mufflers.
    Matt
    Portland Oregon
    I too am running a scabbed together combo on my Saleen. Up front there are some used Ford Motorsport headers. A used BBK x pipe with cats in the middle. And out back some used 40 series Flowmasters from an 89 GT I parted with the original LX stainless pipes to the Saleen. I think it sounds great and I have ZERO drone.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    Jul 2004
    Montebello, CA
    when I got my 94GT parts car it came with flowmasters, they are not too loud but sound good so I think they might be 50's as a women owned the 94 till she crashed into a wall lol
    Past 4 eyes-
    U.S. NAVY 1980-2009
    A lot of newer factory systems have small bullet resonators and mufflers.
    Even with a single rear transverse muffler and or x section.
    Unequal size mufflers in factory systems common. Dual exhaust SVOs were like that.
    Nov 2004
    Chas. SC
    Currently run a MAC system from heads back. They have a bad drone at Hwy speed (3.08 gears approx 2K at 70mph). Plan is to change them out to Dynomax.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Aftermarket performance mufflers are pretty generic.
    At work, seen first hand OEM cats, mufflers, pipes, resonators, being manufactured from scratch, welded or spun type.
    Much more model and engine specific in design, components. Brackets, internals, system reinforcement points, shields.
    Jan 2016
    South Central Ohio
    I've got the Hooker Aerochambers. Nice idle, quiet at road speed, but sound good when you put the pedal down.
    Anyone else find it interesting that a setup nearly identical to my obnoxious exhaust simply has a different brand headers and X pipe and it does not drone where-as mine is absolutely obnoxious?
    FMS vs BBK equal shorties
    BBK x with cats vs Mac x with cats
    Mufflers ... same
    Strange
    Oct 2017
    south-central WY
    Who would think that a minor difference in the weight, length, or shape of a metal tube would change its resonant frequency?
    Jan 2003
    lansing, mi
    Mufflers ... same
    Strange
    I went from BBK un-coated equal length shorties with an h-pipe to BBK ceramic longtubes with an h-pipe in front of the same super 40s Flowmasters with tailpipes on my Capri. It droned something fierce going down the highway before the swap. I did this mainly because I got tired of changing spark plug wires annually, even using heat protective boots with the equal lengths I couldn't keep them alive. While I think the sound of my car now with the 347 is as good as it gets, and it is no longer destroying plug wire, I still wouldn't recommend buying BBK longtubes or their brand h-pipe.
    In the other thread, JACook installed mufflers that were different lengths on his car and claims there is no drone. In my very limited knowledge of sound wave science, this might make sense. I have heard that sounds of the same frequencies cancel each other out, maybe that is what is going on with drone where you are kind of caught in between that with the 2 same size mufflers making the same sounds, only varying in time. Correct me if I'm wrong.
    This brings about another question, has anyone experienced drone in a vehicle with a single exhaust?
    Cale
    Direct fit mufflers are getting hard to find. If a supplier has one, they don’t seem to have the other side. It would seem they all use the same on left and right mufflers. If you look at the direct fit drawings, you can clearly see the right side is a shorter muffler.
    I found a mid pipe which should fit but everything is 2.25”. Mufflers can be 2.25 and 2.5” but tail pipes are mostly 2.5”.. I’m in CA so I have to stick with the single CAT and the near obsolete 2.25” mid pipe. The infamous 2.5” late CFI version has not been available for quite some time. I found a replacement 2.25” mid pipe on my car. It now has holes in it. New one is due today. Next is some 2.25” mufflers
    I’m telling you - I’m more thankful every day that after less than 2 years I left Foster City and moved back to Nebraska in the late 90’s. Weather here isn’t great but at least I don’t have tree huggers telling my I can’t mod my car. The same tree huggers that are out blowing trannys ..... you decide which type
    yikes.
    good luck getting things together in a compliant manner
    Mar 2009
    Gaithersburg MD
    Keep the Flowmaster change mid pipe...Chambered mufflers need h pipe.....straight through mufflers like Turbos need x pipes
    FEP Member Dogster's Avatar
    Nov 2005
    Huntington Beach, CA
    85 GT 5/0 came with different size mufflers for scavenging effect, so I've read.
    '85 Mustang GT Convertible, Jalapeno Red, Charcoal Int., Black Top, 5.0 H.O., 4 bbl , 5 speed, No AC, All original except for 8.8 Motorsport rr w/3.55 gears & subframe connectors. Owned since 'August 86. 1 of 574.
    FEP Member kingsnake's Avatar
    Oct 2008
    Dearborn, Michigan
    Running DynoMax ultraflows here. Sound great. They start to droan around 90MPH with a 3:55 gear.
    I have a full Midas OEM exact fit exhaust laying around that I never used. It is 30 years old. The mufflers are still in the boxes and one is definitely shorter.
    I think it is the right one.
    Could not be better said.
    Portland Oregon
    Mufflers ... same
    Strange
    I forgot to put in my post that my FMS headers are unequal length. That is the only difference I can see other than brands.
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
