Results 1 to 25 of 26
    Default Convertible Door Window Replacements
    Does anyone know where I can find replacement convertible door windows? I have been able to find replacement windows for non convertible/t-top cars on the usual restoration sites, however I haven’t had any luck for convertible specific replacement door windows. Would be for an 86.
    Thanks,
    Matt
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Are you looking for NEW or good used window glass?
    I have had good luck using car-parts.com to find door glass if good used will work for you.
    The 83-early 88 convertible door glass will work for your 86. Once Ford switched to the body mounted Post style mirror mid 88 the door glass changed. Good Luck!
    Hi Trey,
    Thank you for responding. Honestly, I would take either at this point as long as the used was in good condition obviously.
    i will have to check out the site you provided to see what’s out there. Also than you for the tip as to the differences in window between years, I learned something new today!
    Matt
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Looks like this place may have what you need.
    https://www.billfoxsautosales.com/
    I think I may have found a replacement off an 86 convertible. Are there any questions I should be asking? Are the windows the same for car with manual and power windows? That’s probably the main thing I’m concerned with before buying.
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Windows are the same. Obvious the regulators are different between a manual and power setup.
    Portland Oregon
    Was tinted glass (sun-x) standard on the fox bodies or was it an option like on the early Mustangs and Mustang II's? Just curious......
    67 Mustang Coupe
    96 Tangerine GT
    86 Saleen #179
    I know there is tinted and clear glass for the Foxes. I am not sure how/when/why one is installed over the other. Foxchassis would probably be the better one to ask that question.
    Have dealer brochures for my 79 Mustang and 85 LTD.
    Clear was standard.
    Tinted glass was optional on both. Was recommended but not included with a/c.
    My 79 has no a/c but has tinted glass complete, a 59.00 option.
    Clearly remember back then thought it odd to have full tint and no a/c.
    Tinted windshields, or even top band tint only, started in the late 50's, far as i can find.
    Still having some issues finding one of these. For the few I’ve actually found I’ve emailed the sellers and have received no response. I don’t get it, if I had an interested buyer contact me I’d make sure I responded back, especially given the current state of the economy.
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    84 convertible was standard tinted.
    Do you know if the side windows on a 86 convertible were tinted? It is a non AC csr.
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Tinted windows were standard on convertibles in 84 and this probably continued thru 93 as they standardized options. With or without ac.
    I think I found a nice one but the description says 87-83. Based upon what you had described this may or may not work for my car?
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    In the 1986 model year tinted glass was recommended with A/C but it was not required. Tinted glass was standard in convertibles and SVO. It was optional otherwise.
    I will check my glass book later for all iterations of convertible door glass.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Quote Originally Posted by Matt1986gt View Post
    If they can send you a picture of the glass or even a picture of the door it will be easy to tell. If the mirror is still on the window frame then it will fit your car. If the mirror is the paddle style mounted down on the body, then the window is different and will not work. Hope that helps!
    I don’t have a pic of it on a car. This is one of the pics that are listed. Not sure if this helps at all
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    Convertible door glass changed between Sep and Oct 1987 (1988 model year)
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    The NAGS catalog that I have is dated 1999. That's why some models on that scanned page stop at 1999.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I have both sides convertible glass from doors I got a long time ago. I'm in AL though, shipping might be a bit steep for even one. I'd have to dig them out of my basement and separate/verify them from the non conv glass I have. If you're interested.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
    Quote Originally Posted by billkandi View Post
    i had found one but not sure if it occurred during shipping but there was a scratch in the middle of it so for now I kept the window that I already had. I may have to look into a place that can polish it to see if the scratch can be removed. What type of condition is the one you have?
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
    I saw some new ones on ebay
    I’ll dig them out and check, I don’t think they’re scratched, been some years since I messed with them.
    84 Capri RS Turbo
    Could you share a link? I haven’t been able to find for a convertible
    Previous:
    79 Notchback
    86 GT
    93 GT Convertible
    Current:
    86 GT Convertible
