Nice! Great info!
So, the picture becomes clearer. I think it's pretty clear the O2 wiring DID change around the time of the change to MAF. The O2 8 pin connector below the intake tube didn't appear until then. That is a change, no? Ox, let's look at your pics one by one.
1st pic: So, I'm assuming this is a plug that is unplugged in an auto, but plugged in on a manual? And from there, it goes to the clutch switch, correct?
2nd pic: Nice to see I wasn't wrong about the red with blue circuit.
That IS what is shown in my pre-MAF EVTM. It does not address the blue with yellow circuit at all though.
3rd pic: This is the connector near the master cylinder, right?
4th pic: Okay, I'm fairly sure I currently do not have 2 plugs coming through that grommet. Probably because I cut one of them off. Hopefully the LMR harness remedies that.
in your post in the other link, it shows that the wire at pin 30 at the EEC is blue with yellow. That jives with what we know about the wiring change around '89. Mine is purple with yellow, leading to the O2 harness, and yours being light blue with yellow never goes there.
Thanks for the explanation about why they did the O2 sensor thing. Makes sense. I wonder if you could say once I get that LMR transmission harness plus having made the change at the O2 harness that I pretty much now have a manual harness.
