Hey all,
Last year I bought my first mustang, my first domestic car, and my first V8.
The car
I bought this '84 convertible from the PO who had most of his work done by "a friend with a shop" so I have no idea of the qualifications of that party.
PO claims he's put about 15k miles on the engine before sale. Yes, I do assume those were all very hard miles.
It is equipped with BP Engines 306 crate (https://blueprintengines.com/product...block-bp3060ct)
Mechanical fuel pump (unknown pressure)
Had a very rough looking eddy 750 carb on it which seemed like it was too big and also needed a rebuild.
The PO had the wrong type of spark plugs installed, as the threads were too short (.460" i believe, whereas the aluminum heads need a .750") PO also had a baggy in the trunk with what i assume were the previous plugs which were also the same wrong size.
PO also never hooked up the electric choke on that big 750 carb so he would crank the thing for 30 seconds until it started.
All of this above combined for me to bring the car home and find that the breather caps smelled like gas. I knew the oil level was high, but my inexperience didn't raise a flag.
I drained the oil which also reeked of gas, changed filter. Cut open the filter and didn't see any glitter.
I pulled the spark plugs, discovered that they were fouled with oil, and then also found that they were the wrong size.
My theory was that with all of the PO cranking with no choke, the carb being too large, or the carb being in poor condition led to fuel leaking down the cylinder walls into the crankcase. This leaned out the oil and raised the level, and the lean oil was making it's way into the combustion chamber.
Now, I have replaced the carb with an eddy 1905 (https://www.edelbrock.com/avs2-650-c...-egr-1905.html)
Replaced the plugs with proper size and heat range.
Fed it some pennzoil platinum 5w/30 synthetic and new motorcraft filter
Installed wideband 02 sensor/gauge.
Properly set choke and am currently testing some different rod/jet combos.
I checked the spark plug on cyl5 (easiest access) and found that the plugs are still fouling with oil.
Compression seemed ok across the board with lowest cylinder reading between 150/155 and highest cylinder reading 165ish (COLD ENGINE TEST)
I do not have a leakdown tester, and it seems the cheap ones are all horribly reviewed.
If any of you have experience with all 8 plugs fouling with oil, is it usually always worn rings?
I'm really hoping that someone has had a different experience and can give me some optimism to look elsewhere.
Thanks,
