Ok, not a total noob, had a '94 GT 'vert back when they came out but that doesn't count. Searched these forums a bit and think I have come to a consensus opinion, but just wanted to confirm a question regarding 79-82 vs 83-86 cowl interchange.
It would appear that the wider cowl from the 83-86 is easily swapped (drill a couple holes) onto the early cars, but going the other way is a problem? Zapping shut a couple screw holes is no big deal, but is it the case that the air opening itself is a significantly different shape on the 83+ cars and the earlier grill cannot be used without cutting and pasting the cowl sheetmetal itself from the earlier car?
Thanks in advance
