Results 1 to 20 of 20
Thread: What sway bars?
    Feb 2020
    Leon County, FL
    Default What sway bars?
    I’m looking at upgrading the sway bars on my 1986 SVO so it’ll stay flatter than it does currently. What aftermarket bars would be best for an otherwise stock suspension?
    Sep 2010
    Lexington, MA
    You should install SFCs first. Weld-in style. Those improve handling dramatically.
    Feb 2020
    Leon County, FL
    I’m guessing those are the sub frame connectors people have mentioned to me a few times now?
    Sep 2010
    Lexington, MA
    For sure. They make a huge difference
    Feb 2020
    Leon County, FL
    What’s the difference between weld in ones and other ones?
    Sep 2010
    Lexington, MA
    Quote Originally Posted by ClayBelt View Post
    The weld in ones provide maximum support. You won't even be thinking about sway bars after these
    Feb 2009
    Jackson, NJ 08527
    I have these on my dads LTD. Huge upgrade on that of course.
    Very flat, even without performance springs or shocks.
    https://lmr.com/item/EIB-35103/79-93...EaAgXZEALw_wcB
    Feb 2020
    Leon County, FL
    I for sure like the specs for those. Think they’re the same thickness as the ones on my grand marquis, and that thing is pretty flat, so I can only imagine how flat the SVO would be with them.
    So based on all that, I’m currently thinking a set of BBK subframe connectors (the bolt ons, to be welded in at a later date) followed by the Eibach sway bars are in my plans for the future once it’s street legal. Does that sound like a decent enough plan?
    My .02 on SFC is don't waste your time and money with most other options. Maximum Motorsports Full Length are the way to go. The Stifler setup would be my only other option besides MM.
    The bolt in SFC don't provide the same stiffness and eventually will wallow out the bolt holes over time. I understand you plan on welding at a later date, but just save the time and trouble and do it right the first time IMHO. Good Luck!
    I'll 2nd Trey's subframe connector suggestion. They're definitely something you want done the best way possible.
    Thomas
    Feb 2012
    Mississauga Ontario, Canada
    I also agree, I had weld in sfc on 86 T-top and now on my 85 T-top. Massive difference
    Go with MM full length, weld em' in and don't look back. Tremendous difference in how solid the car feels.
    Jeremiah
    1986 Mustang GT 5spd, 3.27's
    Feb 2020
    Leon County, FL
    What’s it usually cost to have connectors welded in?
    The SVO uses a unique front swaybar. You can't just bolt on a "standard" Fox front swaybar. The endlinks will be quite misaligned.
    Modifying the suspension on your car is tricky, because many of the parts were pulled from a Lincoln and other of the parts were made just for the SVO to be able to bridge the geometry gaps between the Lincoln and Mustang parts. The front swaybar is a good example of that. It is a totally unique part used on no other car.
    Jack Hidley
    Jun 2005
    Woodstock, Georgia
    Yep I had mentioned this in one of his other threads. I had also recommended sub frame connectors first.
    Side note make sure the suspension is fully loaded with the weight of the car and the doors are closed / latched before welding.
    86 LX Coupe 4E
    85 SVO Hertz 4E
    85.5 SVO 2R orig owner
    86 SVO 7B
    66 Fastback
    55 Willys Jeep Overland Wagon
    Feb 2020
    Leon County, FL
    Alright, I guess that unique sway bar removes that from the realm of possibilities up front. Might still do the rear at some point depending on how I find the subframe connectors and if I can figure out what size the front one is
    The front swaybar on your car is 1.20" diameter. The arms are 6.75" long (right angle length) and the eyelet width is 45". This makes the arms 0.45" shorter than a standard Fox Mustang swaybar and the swaybar 3.375" wider.
    You can change the front swaybar, but to do this, you need to install new FCAs which have the endlink hole in a different location. Due to the construction of the SVO FCAs it is very, very difficult to move the swaybar endlink hole on them.
    If you're looking for the best handling improvement for the dollar, full length subframe conncetors and a Panhard bar are it. They make the car ride better and handle better, with an improvement in NVH.
    Jack Hidley
    Jan 2016
    South Central Ohio
    Yup, the Subframe connectors will help more than the sway bars.
    Feb 2020
    Leon County, FL
    Sounds a lot like I need to get out of my BOF worldview for handling then and get me some sub frame connectors
    As many of us have stated the full length SFC are money well spent on any Fox Body vehicle. The installation of SFC ties the uni-body together and provides a much stiffer and rigid chassis than what you currently have. That allows the suspension to actually do it's job and do it better. If after installing the SFC you still want to make improvements in handling that is fine, but as stated above you will be pleasantly surprised how much better your SVO drives, rides, and handles with just the SFC. The SVO suspension is pretty decent setup for an OEM suspension. Yes, you can make improvements in many areas depending on your needs/desires but starting with a solid/rigid foundation will allow you to make better choices and fully realize the benefits of any changes. Good Luck!
