Results 1 to 7 of 7
    Feb 2018
    Saskatchewan, Canada
    Default Stock fuel line removal
    So going to be removing my stock fuel line on my 84 to run new braided line along with electric fuel pump, filters etc. Never done this before so any tips would be appreciated. Do I need to lower gas tank? Looks like the hard line runs to the tank and then connected to rubber hose. Do I just disconnect line from rubber hose and run braided from the hose? Also I believe the carbed 84 had a return line. Is that needed if I'm running a electric pump( holley black)?
    Mustangs
    84.5 Gt T-top
    85 Gt
    The Tank needs to come down. Remove all the rubber lines and hard line. You need a fitting to convert from the stock pickup to AN line.
    Feb 2018
    Quote Originally Posted by badnightrain View Post
    Thanks, do I need to run a return line?
    Mustangs
    84.5 Gt T-top
    85 Gt
    You will need to regulate the pressure way down for the carb. Run a return from the regulator to the tank. 6psi from the regulator to the carb.
    Feb 2018
    Thanks, that's what I will do. Does it matter if I use same size hose for return? I'm using 6an.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Feb 2018
    Guess my next question is what's the best way to remove stock lines from where it runs into passenger side wheel well? Do I need to remove tire and wheel well plastic? Dont really care to much about keeping stock lines. If I can get em out easy then I will if not I dont mind cutting them.
    Mustangs
    84.5 Gt T-top
    85 Gt
