Results 1 to 16 of 16
    Default Engine bay body color or black?
    Working on a 79 notch. 4 to 8 cyl swap. It wont be a show car but will take it to shows and cruised around. Going to hide wires and such and make it look nice.
    Is it bad to do it in black? Like frowned upon? Car color will be velocity blue.
    79 Notchback 2.3 cyl to 347 & t-5 swap 65K
    90 Hatch 5.0 T5 Donor for 79
    67 Fastback full resto 289 + c4
    86 GT 5.0 5-Speed T-Top - Gone
    92 5.0 Auto Hatchback - Gone
    89 5.0 5-speed Notch - Gone
    Dec 2006
    Middletown, DE
    For my .02 worth, I vote body color definitely.
    85 Mustang GT
    My .02 is the body color looks much better and is correct for the Fox body, so that is my first choice. The black engine bay was standard with the 60's Mustangs, but just looks out of place in the Foxes IMHO. Good Luck!
    I agree with everyone else on here, color match the car! On a side note, how are you tackling the mass amounts of vacuum lines on the firewall itself? Removing them, taping them? For the wires as well, what are you doing to get paint behind everything - maybe it's a dumb question as you are doing a V-8 swap and have everything gutted. I just would really like to do this to my engine bay, but holy moly - I don't even know where to start. Post some pics if you can!
    Jan 2004
    Olathe, Kansas
    Mine is gonna be black, but that is also the body color LOL
    Now stang-less.
    88 Cougar 5.0
    I agree with everyone else, body color looks best. I am also currently working on cleaning things up in my engine bay since I had my intake off i thought I would take care of other things like the wiring, painting a few things and replace vacuum lines. I am going to pull my wiring harness out and re-tape it then feed it back in to try and hide it the best I can. No clue how ill hide the vacuum lines yet so I am also interested in how you do yours.
    Here is a pic of where I am at before I started the wiring and ill post after pics also
    If you don't want to pull wiring and other major parts and pieces in the engine bay for painting. I highly recommend buying some cheap aluminum foil from Walmart or the Dollar store. Use the aluminum foil ask masking for the wires and odd shaped parts/pieces. Shape it to the wires, parts, etc. and with just a wrap of tape it will stay in place. Great stuff for engine bays and hard to mask items. Good Luck!
    Engine bay's looks better with body color in my opinion, That is what I did but it is a lot of work. I wire tucked mine and filled in all the holes for a smooth look.
    Bob
    1967 mustang coupe -sold
    1967 cougar GT - sold
    1984 Mustang L 5.0L - Totaled
    1984 Mustang GT 5.0L
    2007 Mustang GT convertible ( wifes car)
    1997 F-350 powerstroke
    USMC Retired 1981-2001
    Apr 2016
    Sprague River, OR
    I vote no for black, but body or offset color is a yes. When I did my v8 swap, I welded a few of the holes closed and painted mine "aluminum" which came out a light silver. My car is wrapped, so can be green or purple depending on the view point. A complimenting lighter color would be a good option.
    Join The Conversation
    Dec 2009
    St. louis MO
    This trick works awesome!
    Keith formerly STLPONDS
    '79 V8 coupe in the works!
    Ok will go the body color for the bay...unless i paint it black Heres where I sit.
    Engine bay in Velocity Blue will look much better! Good luck with the project looks a lot like many of mine!
    Black is nice (and clean), but I think the matching body color takes it to the next level! The hardest part is removing everything, and you're already there... Velocity Blue all day!
    Dec 2009
    St. louis MO
    Since you're at that point I'd go body color for sure.
    Thank you for the opinions. Body color it is.
    Still up in the air with... efi or carbed
