Results 1 to 8 of 8
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Default 1980 Junkyard coupe with carraige roof
    Went to the local PnP last week after seeing a post on a local FB group with back end of it in the background. It did not show up in the inventory.
    3.3 Inline 6 coupe.
    I found the build sheet also but it was oil soaked and pretty much illegible.
    Darran
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Interesting is what looks to be an aftermarket carriage roof added to the car. It has non-OEM custom interior and exterior moldings etc. Wondering if this was a dealer or other addition.
    Any thoughts?
    Fit inserts around the rear window. An extra molding on the inside of the quarter window I've never seen.
    VIN
    1FA = Ford vehicle manufactured in USA
    B = active belts, no airbags
    P = passenger car
    10 = Mustang 2-dr sedan (coupe)
    B = 3.3L I6 engine
    0 = VIN check digit
    B = 1981 model year
    F = Dearborn Assembly
    198404 = 98,404th 1981 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 05/81 = May 1981 build
    GVWR - 3736 lb/1694 kg = gross vehicle weight rating
    Front GAWR - 1937 lb/878 kg = front gross axle weight rating
    Rear GAWR - 1819 lb/825 kg = rear gross axle weight rating
    F0162 = 0162 lbs front accessory reserve load
    R0089 = 0089 lbs rear accessory reserve load
    Exterior Paint Colors - 6N = Bright Yellow
    DSO - B6 = Western Ford of Canada district sales office
    Body - 66B = Mustang 2-door sedan (coupe)
    VR - AW = Diamond grain carriage roof (A), White top color (W)
    Int Trim - DA = cloth & vinyl seating, low-back front buckets (D), Black interior trim color (A)
    AC - [blank] = no factory air conditioner
    R - 7 = AM/FM stereo radio with cassette tape player
    S - [blank] = no sunroof, no T-roof
    Ax - 8 = 2.73:1 axle ratio, conventional (non-locking) differential
    Tr - W = C-4 automatic transmission
    VV = front springs
    GG = rear springs
    Buck Tag
    MUSTANG = Mustang model line
    66B = Mustang 2-dr sedan (coupe)
    B = 3.3L I6 engine
    031_ = body & paint rotations #031_
    6NN = Bright Yellow exterior paint color
    SCT = simulated convertible top (carriage roof)
    ST
    02 = YES rear defrost
    RA = road abrasion coating (lower bodyside protection)
    RM = rocker molding
    PW = power side windows (no power door locks)
    01 = no hood scoop
    V = visibility (light/convenience group)
    ELECTRIC
    -A = Black interior trim color
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    82GTforME's Avatar
    Feb 2013
    Alberta, Canada
    Door Tag
    Buck Tag
    So it came with a carriage roof. Is this the factory look or a replacement along the way? It does not look like the ones I have seen previously.
    Yes, it came from the factory with the carriage roof option. Haven't seen enough of them in original factory shape to know what's factory and what's aftermarket replacement.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I think the 79-81 just had a vinyl top. I've seen some of those but, not one like this. Guessing aftermarket.
    It had a carriage roof from the factory assembly plant. Carriage roof was an option in 1980 and 1981. Vinyl roof was an option in 1979 through 1982.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
