Fire up the way-back machine Anyone know the capacity and type of transmission fluid that is specified for the Tremec SROD? I've found mixed results online and in here...dating back to 2014. Type-F, Redline MTL, Autozone shows ATF+4 or Dexron/Merc.
I have mine out to replace the gaskets. I assume I can simply refill from the top before I put the cover back on....anyone know how much it requires or do I just fill until hit's what I think is the fill-plug on the passenger side? I have a tail-shaft plug and speedo port plug so leakage won't be an issue on the re-installation.
