Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: ssp wheels
  1. #26
    And you want the wheel (shaft) centered! It looks right and it keeps the steering equal to both sides. On the pickups with the recirculating ball steering box, you can hear the pump whine if the shaft isn't centered (well, worse than a ford PS pump whines anyway).
    Kenny
  2. #27
    If you replaced the R&P that could be the issue. The R&P has to be centered on it's travel to allow the steering wheel to be centered without major adjustments.
    The steering rag joint generally wouldn't be the issue. Possible to be off if the you installed the rag joint 180 degrees out, otherwise it will most likely be the rack and pinion being off center internally.
    What position is the steering wheel in when the front wheels are pointing straight? Do both tie rods end have roughly the same number of threads showing on the outer tie rod end?
  3. #28
    Mar 2017
    middleboro massachusetts
    I did replace the rack.he had mentioned that,if he had set the wheel where it was straight,he said I would have never been able to drive the car.he also mentioned that he said he centered the rack.and aligned it where everything should be.it drives nice and straight.but the wheel is way off..nothing is easy..what to do next? I guess I can check the rag joint and if that isn’t it,take it a step further.I don’t have much knowledge about all this.120 bucks for a alignment...I wasnt expecting this..
  4. #29
    Mar 2017
    I will look at these tommorrow and see what I find..
  5. #30
    OK, If you alignment guy actually centered the rack and aligned it that way, it should be an easy fix. I would set the wheels nice and straight, then disconnect the steering shaft at the rack and pinion. Verify if the steering shaft is aligned on the rack and pinion. I can be installed incorrectly and not aligned and that can cause the steering wheel to be off. There is a flat spot on the spline and the bottom of the rack joint/steering shaft. Align those two spots and that should hopefully straighten your steering wheel.
    If by chance the bottom of the rag joint and the R&P are in alignment, then the next most likely issue would be the two sections of the rag joint. Make sure the bottom of the rag joint is aligned with the R&P, then disconnect the two bolts that hold the rag joint together, rotate the top of the joint 180 degrees and see if that fixes the steering wheel issue.
    The only other area that I can think of that would allow the steering wheel to be way off would be if the column is the 79-early 83 splined steering column and wheel. I believe yours is an 85/86 and that would have the D shaft that only allows the wheel to be installed one way. The splined shafts can be misaligned if you aren't paying attention. Easy way to check the column is to pull the horn pad and look underneath. If you have a shaft with a nut holding the steering wheel on you have the earlier column. If you have a shouldered bolt holding the wheel on then you have the mid 83 and later D style shaft. Hope that helps and good luck!
  6. #31
    Mar 2017
    wow!! Thanks!! Great info.
  7. #32
    Mar 2017
    Looking for a full set of black lug nuts for 1985-86 ssp wheels.Are they a special type?any help or link would be appreciated
  8. #33
    Mar 2013
    Where the Navy sends me...
    No, they're not a special type. Find some black 1/2" conical seat lug nuts and you'll be good to go.
  9. #34
    Mar 2017
    Thanks Patrick!
