Results 1 to 13 of 13
    Default Proportioning Valve Delete Question
    In the process of deleting the stock proportioning valve, I can't seem to find the correct fitting to adapt the 7/16-24 nut that's on the line out of the rear of the stock proportioning valve to the 3/8-24 brass T that's being installed to tie the front brake lines together. I have an adapter that's 7/16-24 female IF to 3/8" male IF, the issue I find with this is the line sizes are 1/4" and 3/16" respectively. Does anyone make an adapter of this flavor that's designed for 3/16" line on both sides?
    I found this:
    https://www.summitracing.com/parts/e...1erl/overview/
    However, I'm concerned that the 7/16"-24 will once again be for 1/4" line.
    I plan on going with a 94/95 Cobra M/C with a couple MM adapters that will allow 3/8-24 fittings, which will play nicely with my FMS adjustable proportioning valve.
    Any assistance is greatly appreciated! Can this be done without cutting and reflaring?
    Jeremiah
    1986 Mustang GT 5spd, 3.27's
    So Jeremiah, I see no one responded in a year. Did you come up with a solution? I'm looking for a tee to delete my stock proportioning valve in my '82. Anything you recommend? Did you try that one from Earl's at Summit?
    I did, the adapter I used is the same one used when adapting the passenger side front brake like to the SN95 style rubber line. A 7/16-24 IF Female to 1/8" NPT adapter was used to connect the MM brake line to the FMS adjustable proportioning valve.
    Jeremiah
    A 3/8-24 inverted flare 'T' was used for the rear brake lines.
    Jeremiah
    Quote Originally Posted by Two86fiveoh's View Post
    That is a really sweet way to plumb that! Nice job
    Thanks!! That's exactly what I was thinking about doing. Appreciate the response.
    Can I hijack this thread and ask where do people run the adjustable proportioning valve when they dont delete the factory one? Mine will be gutted but I dont want to remove it completly.
    1979 Ford Mustang Pace Car
    4.6 2V conversion underway!!
    Grand Rapids, MI
    On a lot of fox body cars there is a brake line union in the engine compartment on the passenger side up by the firewall. It is up high by the cowl so it is easy to see. I cannot remember if the early cars had that or not. That is the easiest place to put it.
    http://www.maximummotorsports.com/as...es/BPV-1r1.pdf
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    Early foxes had a 90 degree fitting and the brake line runs inside the car.
    I want to keep the stock proportioning valve even though its gutted, I have the wilwood adjustable unit that is the most common, it looks identical to the ford racing unit.
