Results 1 to 13 of 13
    FEP Member Sask84gt's Avatar
    Feb 2018
    Saskatchewan, Canada
    Default Need help identifying a cut wire.
    Anyone know what this cut from and what its purpose is? It's off the main harness on passenger side. Car is a 84 gt.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Feb 2009
    Jackson, NJ 08527
    Typically that large yellow wire is the feed for the ign switch and ultimately everything that gets turned on by the ign switch
    See 84 wiring diag here.
    http://vb.foureyedpride.com/showthre...79-1986-in-PDF
    Feb 2018
    Ok, so why would it be cut? Seems pretty important to me lol. Note, it was like that when I bought it and also had the motor removed.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Feb 2018
    Looks like it was cut from here.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Just trying to bump your thread and I'm tending to side with those saying it's typical of the large Yellow wire that goes from the ignition switch to the starter relay (aka solenoid). Supposedly it provides power to the inside of the car from its connection at the solenoid and I believe in some cases it's also connected to/with a Fusible Link. Quite a few guys say this Yellow wire enters the passenger compartment on the passenger side under the dash and is connected to the rear window defrost. Maybe some others will chime in to verify . . .
    If you take a look at the first minute of this Yootube vid (a empty Fox engine bay) I'm pretty sure that's your wire attached to the solenoid
    https://www.youtube.com/watch?v=HkMgDLt8DBw
    #1) 1985 Mercury Capri 5.0L 4V 5-Speed T-Roof Motorsport Grand Prix IV
    #2) 1985 Mercury Capri 5.0L 4V 5-Speed T-Roof
    "Tolerance and apathy are the last virtues of a dying society" - Aristotle
    Feb 2009
    Jackson, NJ 08527
    If you still have power to the ign switch and rear defroster (as mentioned, that yellow wire usually powers feed to
    rear defrost relay) then someone ran a seperate non-factory wire instead of the cut one.
    Does ign and read defrost work?
    Feb 2018
    Not sure, motor was out of car. I've been in contact with previous owner and he said it was running and driving before he took motor out due to a leak of some sort. He thinks it's a accessory wire of some sort.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Feb 2009
    Jackson, NJ 08527
    You don't need motor in to see if that is main ign wire. Hook chassis ground up to neg batt and then hook pos side of batt up to yellow wire.
    Try ign switch. If it works, then disconnect that wire, ign will probably not work.
    On my 85, that big yellow wire is for the rear defrost.
    Feb 2018
    Ya that's what previous owner said it probably was.
    Mustangs
    84.5 Gt T-top
    85 Gt
    Feb 2018
    Update
    Hooked up battery and had power to inside of car and also starter so that yellow wire must be rear defrost.
    Mustangs
    84.5 Gt T-top
    85 Gt
    As others have said , yellow is rear defrost. The two light tan wires are fog light power. Tan wire is from the passenger marker light and runs to the fog light switch as one power for a double power relay. Black wire is the ground for the fog light switches light.
    84 20th Anny 2.3Turbo #1978
    84 Turbo GT 11.70@120MPH 418RWHP
    89 41X Coupe 2200 miles
    96 Mystic Cobra Terminator swap
    Feb 2018
    Quote Originally Posted by GT350R View Post
    Thanks for the info, I'm going to attempt to solder them all back together.
    Mustangs
    84.5 Gt T-top
    85 Gt
