Page 12 of 20 FirstFirst ... 21011121314 ... LastLast
Results 276 to 300 of 493
  1. #276
    Quote Originally Posted by tonysilver82 View Post
    Attachment 133061fuel tank in place for racing gas for nitrous
    Looks great, nice job!
  2. #277
    Finally got my windshield installed today! Now I can finally move on with the project after being waylaid by having to remove the cowl and replace the rotted section.
    Lower drivers trim piece is a little bent but glass guy said it wouldn’t leak just cosmetic.
    Car has been hit, and it could have been like that before and didn’t notice.
  3. #278
    Installed a new battery and some repro battery cables then went to a cruise night with my brother.
    Name:  battery install.jpg
Size:  132.7 KBName:  cruize night (2).jpg
    85 GT - owned since 87
  4. #279
  5. #280
    May 2014
    Royal oak Mi
    Installed 4 cylinder springs and cut 1/4 coil out of them and removed isolators
    It's low and dropped it probably too much but so far so good
    1-3/4 rake
    Max motorsports adjusted down rears to help with exhaust clearance and Michigan pot holes
  6. #281
    May 2014
    Royal oak Mi
    Attachment 133089
    Attachment 133090
    Attachment 133091
    Before and after with gas can for scaleAttachment 133092
    I'm switching to eibachs and 17 inch non stagger ponies but had to get the nose down granted this is not ideal and im surprised it rides as well as it does
    If I lower the rear 1/2 more its not happy going into steep driveways
    If I add the isolators back and add 17s it should sit right
    I have new control arms going in when I do the swap
    1/4 coil removed
    Spring meaures 13-3/4 tall i cut them at 13-1/4
    Ground to fender is 24-3/4
    Ford emblem is knee height in front
    Only driven 800-1200 miles year so no worries on how wrong the geometry is i get it
    Rides crazy nice from factory height
    Was only looking for 3/4 drop and I was shocked how little removal dropped it what it did
    These coils supported a bbf 545ci foxbody drag car in early 90s
  7. #282
    Default sticker sucker
    Maybe will see ya out there on ww JP
    On recent nice fri-sat evenings, we been sitting on ww across Pasqualis on the gas station side street.
    Starting to reinstall and or restripe the body side moldings and bumpers with 1/2" 3M red reflective.
    Car came with orange Cobra graphics and red pinstriped moldings.
    Found this stuck in a front wheel well liner gap.
    At final inspection of tape from a distance, looked like discarded white tape liner.
    Will never know how it got there. Recent, fairly clean and sticky.
  8. #283
    May 2014
    Royal oak Mi
    I'll look for your car.. foxbodies stick out some with all of the newer cars out there.
    This Saturday I believe is telegraph cruise but don't hold me to that
    Nice progress on project
  9. #284
    Jul 2004
    Montebello, CA
    I am working on replacing the transmission tail shaft bushing and seal after a major fluid leak but after I removed the driveshaft I saw the pinion seal was kinda leaking a little so I will be replacing that to. But I think im going to take the drive shaft over to get the U joints replaced and have the shaft re-balanced as im using a auto shaft with a 5 spd.
    Past 4 eyes-
    U.S. NAVY 1980-2009
  10. #285
    Mar 2003
    Lowell, Oregon
    S-l-o-w-l-y getting it together... Passenger side done (exc for seatbelts. Need to remove trim from one set and install on the red set. Drill the rivets out, etc) Driver side will be done after I install the Steeda quadrant kit.
  11. #286
  12. #287
    Got this done today
Size:  234.5 KB Name:  oWzWip.jpg
Size:  248.8 KB Name:  victog.jpg
    This was a mock up to see how these wheels will fit the car, I think they fit pretty good. Now I can push the car outside and swap axles to see how the rears fit.
    I also used the Eastwood internal frame coating, you can see it dripped out of some of the holes.
    it seemed to work pretty good, was able to coat both sides complete front frame rails by using a length of tig filler rod to guide the nozzle.
  13. #288
    May 2014
    Royal oak Mi
    nice progress
    Cool build
  14. #289
    Quote Originally Posted by Jerry peachuer View Post
    nice progress
    Cool build
    Thanks for the kind words!
  15. #290
    Jul 2004
    Montebello, CA
    soooooo I buy the special tailshaft bushing tool..... I buy 2 more new bushings........ I install the 3rd new bushings and again I cant get the driveshaft to push into the bushing! WTF! is it such a tight fit and is squeezing the bushing? can I cut the bushing to give it more room to go into the tailshaft?
    Past 4 eyes-
    U.S. NAVY 1980-2009
  16. #291
    I had this exact problem once. What I found is that the opening I was driving the tailshaft bushing into is out of round. We ended up pulling the tail section of the transmission and putting on a different one. I've had a brand new "won't go into 3rd correctly" problem ever since - so it will come back apart again soon.
    For round 2 I'll probably put a bit in a drill press and machine off the part that's out of round on the old housing and put it back together.
  17. #292
    May 2014
    Royal oak Mi
    Size for size slip fit its precise and depending on who and where you purchased the bearing it is tolerance stack up
    Expandable reamer or maybe even small honing tool could massage the fit
    A good used input yoke could be your under car friend but you do want this to not just fit but nice slip fit and square
    Your first edge may have a burr on it from pressing it in
    I made a plastic tool to insert the bushing which is softer than the brass and worked good socket and hammer shouldn't be used here for install but it could work
  18. #293
    Jul 2005
    Medicine Hat, Alberta,Canada
    Did this the other day....red carnage...lol!Name:  20200706_221900.jpg
    Sent from my LG-H873 using Tapatalk
  19. #294
    Jul 2004
    Montebello, CA
    the special tool I bought came with the bushing driver (cost me $180.00) all the new bushings fit the yoke and even the last bushing I installed had a cut and still I can only push in about 1/4" maybe ill try the original bushing but ill put it in the freezer to shrink it for easy install
    Past 4 eyes-
    U.S. NAVY 1980-2009
  20. #295
    Was the transmission mishandled while it was out sometime? The tail sections do crush around the output bushing pretty easily.
  21. #296
    Jul 2004
    Montebello, CA
    no the trans was left in, I bought the special 2 piece tool to remove and install the bushing
    Past 4 eyes-
    U.S. NAVY 1980-2009
  22. #297
    May 2014
    Royal oak Mi
    Size for size is a press fit meaning if your i.d is 1.500 and your yoke o.d is 1.500 it will not fit
    It needs .0005 undersize on either piece
    There's probably a .001 press fit to keep bushing from spinning during normal use
    I believe your bushing is so close because it fits already just needs a little hone to be a good fit
    Try to take very little off with a smooth finish
    Your steel input shaft will be spinning on bronze bushing wearing it in when installed and your driving in normal use 2
  23. #298
    Jul 2004
    Montebello, CA
    I tried all the new bushings on the yoke before I pressed into the housing, they were loose so I cant see how when they are pressed in I cant get the yoke in after
    Past 4 eyes-
    U.S. NAVY 1980-2009
  24. #299
    May 2014
    Royal oak Mi
    the cut is for oil drain back there directional specific
    Easier to see with tailhousing off
    Not saying this is your fitment issue but similar to your main beaaring oil feed groove it has a slit
  25. #300
    Jul 2004
    Montebello, CA
    !new bushing was cut not in half but 1 side....
    Past 4 eyes-
    U.S. NAVY 1980-2009
