Been doing some research on EFI fuel systems and thought I would throw out a few questions.
Does anyone know or experimented with using an aftermarket EFI system such as Fitech on a stock 86 EFI return fuel system ?
Also anyone know if the stock in-tank fuel pumps are compatible with the pulse modulation (PWM) drivers on the fitech etc ?
I know the stock fuel pumps are not rated for super high HP flows but one would expect that they should certainly keep up with milder builds etc. In my mind excessive flow from a large pump on a return system is probably not very desirable either so the ability to slow the pump seems like a very good feature.
It looks like Ford changed the systems in the later 90's cars to incorporate a fuel pump driver (assume a PWM type system) so I was thinking a stock pump from one of those cars would definitely be compatible if running a system with PWM etc.
