Results 1 to 7 of 7
    Default Help Decoding 86 Mustang GT T-Top Build Sheet
    Name:  Mustang Door Tag.jpg
    Looking for some help here. I have started to restore the inside of my 86 mustang and found the original build sheet for the car underneath the carpet. I have uploaded a copy of it and looking for some help decoding it completely. The Vin # is 1FABP28M3GF183074 Thanks in advance for anyones help.
    Can you post the door tag and buck tag?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    I have uploaded a few more documents for you. Door tag, Buck tag, and axle tag. Looking forward to your help!
    VIN
    1FA = Ford vehicle manufactured in USA by Ford Motor Company
    B = active belts, no airbags
    P = passenger car
    28 = Mustang 3-door sedan (hatchback)
    M = SEFI H.O. 5.0L V8 engine
    3 = VIN check digit
    G = 1986 model year
    F = Dearborn Assembly
    183074 = 83,074th 1986 Ford scheduled for production at Dearborn Assembly
    Door Tag
    Date - 12/85 = December 1985 build
    GVWR - 4075 lb/1848 kg = gross vehicle weight rating
    Front GAWR - 2206 lb/1000 kg = front gross axle weight rating
    Rest GAWR - 1993 lb/904 kg = rear gross axle weight rating
    F0068 = 68 lbs front accessory reserve load
    R0071 = 71 lbs rear accessory reserve load
    Exterior Paint Colors - 9L = Oxford White
    DSO - 24 = Jacksonville district sales office
    Body - 61B = Mustang 3-door sedan (hatchback)
    Int Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior trim color (A)
    Tape - 1 = Dark Charcoal hood stripe, Medium Charcoal Mustang GT decal on hatchback
    R - 4 = AM/FM stereo radio
    S - D = T-roof
    Ax - Z = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - 2 = Borg Warner T-5 5-speed overdrive manual transmission
    OO = front springs
    BB = rear springs
    Buck Tag
    MUSTANG = Mustang model line
    61B = Mustang 3-dr sedan (hatchback)
    TR = T-roof
    0333 = body & paint rotations #0333
    9L = Oxford White exterior paint color
    DF
    ST
    AC = manual air conditioner
    04 = YES rear defrost, YES rear wing
    HB = heated backlite (rear defrost)
    GT= Mustang GT model/trim level
    PW = power side windows (no power door locks)
    MBW = manual Borg Warner transmission (5-speed T-5)
    01 = no hood scoop
    EL
    -A = Charcoal/Grey interior trim color
    EI = electronic injection (EFI)
    04
    1
    X
    4 = T-roof door with power locks and/or power windows
    NLR
    4
    Build Sheet
    Line X
    851217 1224 = build sheet printed on December 17, 1985 at 12:24 PM
    Line A
    Rotations Number - 49_8 = trim & chassis rotations #49_8
    Line - Z = Mustang model line
    VIN - P28GF183074 = [VIN decoded above]
    Body Type - 61B = Mustang 3-dr hatchback
    Body, Tops, Color - [blank] = no convertible top
    Body, Tops, Roof - H = T-roof
    Ext, Paint, Body - 9L = Oxford White exterior paint color
    Ext, Paint, Accent - [blank] = no accent paint
    Ext, Tutone - [blank] = no tu-tone paint
    Int, Trim - PA = cloth Articulated Sport seating (P), Charcoal/Grey interior color (A)
    Int, Deviation - [blank] = no interior trim deviation
    I.B. Color - A = Charcoal instrument panel color
    Type of Order - 1 = Retail order
    Region & District - 24 = Jacksonville district sales office
    Special Order - [blank] = not a special order
    Line B
    Emission Control - [blank] = no special emissions package
    Engine - M = SEFI H.O. 5.0L V8 engine
    Trans - 2 = Borg Warner T-5 5-speed manual overdrive transmission
    Air Cond - M = manual air conditioner
    Engine, Tag Number - ZK341AA = unknown calibration (Z), Thermactor emissions with or without A/C (K), 5.0L engine (341), release level AA
    Therm, Air Pump - MO = 5.0L engine Thermactor air pump
    Transmission, Part Number - E6ZRFB = manual transmission (R) originally engineered for 1986 (E6) Mustang (Z), release level FB
    Seats, Type - 6 = Articulated Sport seating
    Belts, Color - A = Charcoal/Grey seat belts
    Carbon Canister - X = 5.0L engine carbon canister
    Modules, Ign. - 5 = 49-state 5.0L/T-5 ignition module ignition module
    Modules, EEC/MCU - AVM = 5.0L engine, manual transmission, unknown calibraton EEC module
    Air Cleaner, Part Number - E6SB = air filter housing originally engineered for 1986 (E6) Thunderbird (S)
    Bypass or Diverter Valve - BK = 5.0L engine Thermactor bypass & diverter valves
    Line C
    Imm Block Heater - [blank] = no engine block immersion heater
    Power Steering, Oil Cooler - A = power steering cooler
    Power Steering, Pump - R = power steering pump for 3.8L engine and 5.0L engine with T-5
    Power Steering, Hoses - 8G = power steering pump for 5.0L engine with A/C
    Radiator, Part Number - 3ZJ = radiator for 5.0L engine without transmission fluid cooler
    Fan, Part Number - 65A = 5.0L engine fan
    Alternator, Wiring 14305 - [blank] = alternator wiring for 5.0L engine
    Alternator, Code - 6S = alternator for 5.0L engine with T-5 transmission
    Drive Belts, A/C - P = drive belt for 5.0L engine with A/C
    Drive Belts, Power Steering - P = power steering drive belt for 5.0L engine with A/C
    Drive Belts, Alternator - P = alternator drive belt for 5.0L engine with A/C
    Vacuum Solenoid - F = vacuum solenoid for 5.0L engine
    Line D
    Groups, Décor, Appear - B = GT package
    Electrical, Wipers - W = interval windshield wipers
    Electrical, Defroster - E = electric rear defrost
    Electrical, Audio, Radio - S = AM/FM stereo
    Electrical, Audio, Spkrs - 4 = four speakers without premium sound system
    Electrical, Lights, Light Group - [blank] = no light group
    Power Aids, Deklid Release - F = remote decklid release
    Power Aids, Locks - [blank] = no power door locks
    Power Aids, Windows - S = power side windows
    Glass, Tint - T = tinted glass
    Mouldings, Rocker - [blank] = no rocker moulding
    Air Dam - G = GT front bumper cover
    Road Abrasion - [blank] = no road abrasion coating
    Carpet/Mats - G = grey floor mats
    Console - C = console
    Mirror, Vanity - N = passenger side vanity mirror
    Mirror, Outside - A = dual remote control mirrors
    Line E
    Battery - DC = heavy duty battery (54 amp-hr)
    Driveline, Speed-O, Metric - [blank] = imperial speedometer (mp/h)
    Driveline, Speed-O, Gear 2 - Y = Yellow (C0DD-17271-B) speedometer driven gear
    Driveline, Driveshaft, Color Codes - PBW = driveshaft for 5.0L engine with manual transmission
    Driveline, Rear Axle, Tag Number - 203F = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
    Suspension, Springs, Front, Left - MOL = O front left spring code
    Suspension, Springs, Front, Right - MOL = O front right spring code
    Suspension, Springs, Rear, Left - MID = B rear left spring code
    Suspension, Springs, Rear, Right - MID = B rear right spring code
    Stabilizer Bars, Front - YB = Yellow and Blue paint daubs on front stabilizer bar (5.0L bar)
    Stabilizer Bars, RR - B = Blue paint daub on rear stabilizer bar (5.0L non-SSP bar)
    Pkgs, Hndlng - X = Handling Suspension package
    Sus Arm Lower RR - F = 5.0L rear lower control arms
    Line F
    Wheel Area, Wheel Covers - Z = wheel covers w/ embossed Ford oval
    Wheel Area, Wheels 1/2 - ZZ = 15" x 7" cast aluminum wheels
    Tires, Goodyear - 4 = Goodyear tires
    Tires, Size - 22560VR = P225/60VR15 tires
    Tires, Color - [blank] = black sidewall tires
    Tires, Spare - M = mini spare tire
    Tires, Quantity - 4 = four full size tires
    Speed Control - [blank] = no cruise control
    Front End, Cover/Pad - Z = vinyl wrapped GT steering wheel with Ford oval
    Front End, Steering Wheel, Type Wheel - 2 = steering wheel without cruise
    Front End, Steering Wheel, Type of Col - T = tilt steering wheel
    Clusters - 6A = instrument cluster with 7K tachometer and 85 mph speedometer
    Hood Scoop - [blank] = no hood scoop
    Frt License Plate Bracket - X = front license plate bracket
    Line G
    Accent Stripe, Type/Color - G1 = Dark Charcoal hood stripe, Dark Charcoal "GT" hood decal, Silver Metallic "Mustang GT" hatch/trunk decal
    Export/French - [blank] = no French labels
    VIN - 1FABM3 = [VIN decoded above]
    Axle Tag
    203F = plant code 203F
    3SL08 = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
    A88 = 8.8" ring gear diameter
    5M18 = axle assembly built on December 18, 1985
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Can you post transmission tag? Do you have an owner card? Looks like you have a Marti report. Can you post original door tag?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I have posted the original door tag. I have not found the transmission tag or owners card yet.
    Additional door tag info decoded
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
