Results 1 to 6 of 6
    Default (SOLD) 1982 GT For Sale in Crowley, TX (76036) - $8500
    For sale is my 1982 GT. It has been a Father and Son project since 2007, but its time to build something new. Nothing on the car has more than 3000 miles on it.
    1982 Black GT with Red Interior. Had 142,000 on odometer when I replaced with Autometer gauges. Car has a clear Texas title
    Car does not currently have heat or air (I was going to do Vintage Air as the next project on it)
    HO Fibertrends Cowl hood
    Louvers on back window
    1988 GT seats (red)
    New Black Carpet
    New headliner
    Scottrods Dash panel with Autometer gauges (Speedometer, Oil Pressure, Water Temp, and Volts), plus a Monster Tach
    Radio delete panel with temp gauge line lock, and 12 Volt charging Port
    Trunk mount Optima battery with Ron Francis disconnect switch.
    Weld Wheels (15 x 6 front, 16 x 8 back). Newer front tires, back are new Comp TA 245/50-16
    Engine is 408W Stroker (Shortblock build by Morgan & Son). Scat 9000 28oz, 4.00 stroke crank
    Eagle H beam Rods
    DSS Piston (-3cc Pistons, was built to be turboed)
    ARP main studs
    Comp Cams XE-282 HR Cam, Comp Cam pushrods, and roller rockers
    AFR 185 heads
    New RPM Air Gap for 351
    New MSD Billet distributor
    New BBK Headers
    Sumped gas tank (I think from Franks tanks) with Holley Blue fuel pump
    Just professionally rebuilt Demon 650 plus will include a Holley 750 DP
    3G Alternator Upgrade ( I think it is 85 Amp)
    New FAST ignition and Coil
    Transmission is C4 by Broader performance with all of the good stuff. Reverse Manual valve body. 3500 Stall converter by Ultimate Converter Concepts
    B&M ratchet shifter
    Ford Racing driveshaft with safety loop
    Built 8.8 with aftermarket axles, 3.73s and some sort of posi (it came with the car and works great). Just changed the lube and added Ford Racing additive
    Maximum Motorsports lower control arms and Team Z uppers.
    Koni yellow rear shocks and Strange adjustable front struts
    Lots more stuff I'm not remembering and lots of spare parts. I have receipts for just about everything done to the car.
    $8500
Size:  220.7 KBName:  gt_interior.jpg
    1982 Mustang GT - Black with Red Interior
    Engine: Former 306 with AFR 185's, F Cam, RPM Air Gap, Barry Grant 650, Ford Racing shorties, and MSD 6AL. Coming soon a 408. Transmission: Broader Performance C-4 with Reverse Manual Valve body and Ultimate Convertor Concepts 3500 Stall.
    Rearend: 8.8 with 3.73 Gears and Moser Axles.
    New User
    Oct 2015
    Texas Hill Country
    Im a long time member/lurker here. cant send a PM due to the way the board is set up. Have some questions on your car, very interested, can you try to PM me ? Thanks -Dave
    Jun 2016
    Saint Clair MI 48079
    Wow! Nice!
    It was great talking to you yesterday. I'll send some interior pictures.
    Robert
    New User
    Oct 2015
    Texas Hill Country
    Thank you sir. Look forward to it..
    Robert
