Results 1 to 1 of 1
    Default 85 Mustang GT Convertible in GA
    Hello all. Thanks for letting me into the group. I look forward to gleaning all the info I can from the experts here. I've got a 5.0 HO with the CFI and AOD. Its got headers, 410 gears and a limited slip rear end, rebuilt motor (unknown specs) and transmission. I plan on carburating it and adding Blueprint aluminum heads and a cam. Name:  Mustang.jpg
Size:  182.9 KBName:  Mustang.jpg
    [h=WND-8020WND - Weiand Stealth Intake Manifolds]2[/h][h=SUM-M08600VS - Summit Racing® M2008 Series Carburetors]2[/h][h=MLL-HP9009 - BluePrint Engines Muscle Series Cylinder Heads]2[/h][h=SUM-850021 - Summit Racing® Blueprinted HEI Distributors]2[/h][h=MRG-9710 - Mr. Gasket Fuel Pressure Regulators]2[/h]What cam should I be looking at for a good running street car with the above specs? Will put in a stall converter if I have to but probably would rather keep it on the mild side.
    Thanks,
    Mustang Sammy
