Do mustang h pipes fit a 88 cougar
1973 Montego GT 1981 Capri RS (351C)
1971 Cyclone GT 1971 Cyclone GT
1970 Cyclone 1969 Marauder X-100
1970 Fairlane 500 (429SCJ) 1986 ASC McLaren Capri Vert
1985 ASC Capri Coupe 2008 Bullitt 2013 GT 1985 Capri
2001 GT 1994 XR7 1986 Capri
1972 Mercury Montego/Ranchero conversion
Not sure which brand we went with, but a catless H fit's an LTD with no issues
(I know not a cougar, but still a longer fox than stangs).
The one we got was 3 pieces, so I recommend that if still avail, gives you
some adjustment.
EDIT: I looked it up and it was a MAC h-pipe we used. Here is a pic of it.
As long as you have the correct shorty or long tube headers it should fit.
However, not all cougar birds have a double hump transmission cross member but a mustang or turbo coupe or any 88 5.0 car should have it.
Ive had several v-6 cars in 87 that had the double hump and a few 5.0's that didn't.
It wont fit with the stock cast manifolds.
I have stock mustang headers on my 88 cougar, and I used a standard mustang off road h pipe. You will need the dual exhaust tranny crossmember, most likely. I have some SN95 cobra mufflers bolted up to the Hpipe and mufflers dumped at axle.
Deciding what I want for tailpipes, if at all.
Now stang-less.
88 Cougar 5.0
Ok cool have mustang stock headers has a double hump member just thought they were a little longer
Ox1. Like the avatar always look on eBay for those never see them
Stock 88 cougars had cast manifolds?
Weren’t they true duals like a mustang?
