Results 1 to 11 of 11
    Default 1980 Fairmont Door Sticker
    Can someone please decode this door sticker for me please?
    Name:  fairmont door tag.jpg
    VIN
    0 = 1980 model year
    E = Mahwah Assembly Plant
    92 = Fairmont 4-door sedan
    B = 3.3L I6 engine
    205434 = 105,434th 1980 Ford scheduled for production at Mahwah Assembly
    Door Tag
    Date - 05/80 = May 1980 build
    GVWR - 4060 lb/1841 kg = gross vehicle weight rating
    Front GAWR - 2058 lb/933 kg = front gross axle weight rating
    Rear GAWR - 2020 lb/916 kg = rear gross axle weight rating
    F0175 = 0175 lbs front accessory reserve load
    R0108 = 0108 lbs rear accessory reserve load
    Exterior Paint Colors - 8A = Dark Chamois Metallic
    DSO - 14 = Pittsburgh district sales office
    Body - 54B = Fairmont 4-door sedan
    VR - [blank] = no vinyl roof
    Int Trim - BT = vinyl seating, front bench (B), Caramel interior trim color (T)
    AC - A = manual air conditioner
    R - 2 = AM radio
    S - 0 = no sunroof
    Ax - 8 = 2.73:1 axle ratio, conventional (non-locking) differential
    Tr - W = C-4 automatic transmission
    VV = front springs
    SS = rear springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Awesome! Thank you! Is there anything different that the buck tag tells in addition to this?
    Yes, the buck tag has codes that are not on the door tag.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Sweet. I will get a pic next time I'm out in the barn with the car.
    It's weird, the side facing out is illegible.
    Looks like it may have undercoating sprayed on it.
    I don't have many buck tags from non-Capri/Mustang, and I don't know a lot about the codes on them, but I'll do the best I can.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Buck Tag
    A = air conditioner
    R = road abrasion coating(?)
    F
    54F = Fairmont model line (F), 4-door sedan (54)
    8AA = Dark Chamois Metallic exterior paint color
    BW = 3.3L I6 engine (B), C-4 automatic transmission (W)
    X
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    I believe each dash (-) on the buck tag is a place holder for a code. The presence of a dash in each place on the tag is an indicator that the car is not equipped with the item.
    For example, your car has factory air conditioner, indicated by the "A" code...
    - - A R - - - F - - ---
    If it were not originally equipped with factory A/C that line of codes would have a dash in place of the A...
    - - - R - - - F - - ---
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Thank you very much! I appreciate it!
