Results 1 to 25 of 36
    Default 8 bent intake pushrods
    Resolution to this issue is in post #26. Camshaft installed in wrong position.
    Scratching my head on this one. Any advice appreciated.
    NOTE: The motor in question came out of my 86 that was previously rebuilt and driven approx. 15k miles with no issues. The only thing changed before installing in the '84 was the camshaft. I went from an 'F' motorsport cam to a stock 'speed-density' (86-88 HO) cam.
    The combo is roller 306 block, GT-40 iron heads, 1.7 motorsport roller rockers, push rod length unknown at this time... I still need to measure although i suspect stock.
    I installed this engine in my '84 over a decade ago and have just now recently gotten back into the project and got it *sorta* running. It was making some valve-train noise and running overall poorly (rough idle) so I pulled the covers to adjust the valves. In the process of doing so, discovered all 8 intake push rods were bent. Exhaust are fine. It's been 10 years but i'm willing to bet I installed the cam correctly. I did not degree the cam when installing... just brought up to TDC on #1 and matched the dots on the cam & crank sprockets per the shop manual instructions. Didn't think it would be an issue with a stock cam. Nothing binding or felt strange when turning over by hand before the initial fire-up.
    Did I make a mistake in assuming going from the lumpy 'F' cam down to a stock smooth-idle cam that my pushrod length would not be an issue? Nothing else was changed. Heads were not pulled, just front cover & intake for cam removal/installation. I am unaware of what valve springs it currently has. I'd guess they'e a little stiffer than stock, but that shouldn't pose an issue here, right?
    Can't seem to find any specs on the speed-density roller cam. Does anyone happen to have the lift/duration #'s for that particular cam? I know they were slightly different than the later 'mass-air' roller cams from 89-93. I need to do the math with the 1.7 rockers to factor out if that's my issue.
    Thanks!
    86 LX Coupe
    Everything I have seen shows the 86-88 camshaft as 0.444 lift and 266/266 duration.
    I would recommend checking your pushrod length first to verify what you have before making any assumptions. Good luck!
    Thanks, Trey. That's definitely the first thing on my to-do list this afternoon.
    I gather the engine was previously fired and running and underwent a cam swap and was left sitting? What if the problem is unrelated to the cam swap?
    I've heard of and seen instances where an engine sittings for time can encounter issues where the valves get gummed up at the valve stem/valve guides.
    This very thing happened to a 79 5.0L coupe that sat for 4-5 years owned by Doug Kielian.
    I agree -- do measure pushrods. But I would carefully take the pressure off the valve springs and see how much effort it takes to turn the valves in the guide.
    Thinking back to an old engine I worked on while I was a kid. The valve seals basically turned into glue after they were left without oil for years.
    Hey erratic50 -
    You are correct in this engine ran 15k miles with a different cam with no problems. When pulled, it was swapped to the stock cam and put in the car and not fired until several years later. I would occasionally rotate the crank by hand to keep things moving.
    Great point on sticky valves. I have encountered this before as well with solid lifter y-block engines that sat for years and would get sticky and bend pushrods left and right. The fact that it bent all 8 intake pushrods and none of the exhaust leads me to believe sticky valves is likely not a factor here.
    I did measure a straight pushrod last night and it came out to 6.25" (approx. as i couldn't find my caliper and used a ruler). Based on what I've read here, that's stock length.
    For grins, I put in 2 good pushrods on #1, got it on TDC, adjusted to zero lash and rotated the motor by hand about 10 revolutions. No binding was observed. Rods stay dead center in their guides and in the holes in the head.
    Since all the initial work was all done so long ago and I can't recall specifics, could it be that I set the valves in the incorrect sequence and ended up not being on the base circle of the cam and intakes were simply over-tightened? User error? Wouldn't be the first time...
    Thoughts?
    Are the GT40 heads stock explorer fare? Those heads have notoriously weak valve springs and even with the stock HO roller cam would likely float the valves at over 5k rpm's, let alone when you had the F cam in it.
    Quote Originally Posted by Zap's 85 GT View Post
    Zap - They are not the exploder version. Springs were replaced with stiffer ones when it was rebuilt, but can't recall what rate were used.
    I'll have to dig in my receipts.
    May 2016
    Lake City Pa 16423
    If the engine has stock 86' pistons, they are flat tops without valve reliefs. 1.7 rockers increase lift, GT40 heads have larger valves. Everyone of these items tells me you have a valve to piston clearance problem Since all 8 pushrods are bent. Stock pushrods are not hardened and bend easy. Even if they didn't touch just running the engine, at higher rpms they will touch. If you pull the heads, you will see the valves have hit the piston and there will be smiley marks on them.
    You stacked the deck against yourself when you used the 1.7 rockers.
    Jul 2009
    Chicago, south subs
    If the pushrods are bent, you better check the valves too.....
    Quote Originally Posted by dynodon64 View Post
    dynodon64 & gmatt -
    I should've been more specific. It's not an '86 engine, it just happened to come out of my other car ('86). The pistons have valve reliefs. This combo was run with a motorsport F cam (.512 lift) with 1.7's with no issues. Going to a stock (.444 lift) with the same 1.7's would give me even more clearance. This is all with stock length pushrods.
    I'm pretty sure at this point I adjusted the valves incorrectly when the stock cam was installed. Going to do a compression test and go from there.
    Thanks for the help.
    May 2016
    Lake City Pa 16423
    Just because the newer cam has less lift, doesn't mean that the duration and open/ close events are the same for both cams. You have to look at all the timing events of the cams, not just max lift. If the cam was installed advanced or retarded, it will also cause a clearance problem. You have a piston to valve clearance problem or you are having spring coil bind with the intake valves because you bent every pushrod. One other possibility is the 1.7 rockers don't have a long enough opening in them and they are binding on the stud or bolts. Remember, the piston is chasing the intake valve as it closes. That's where it will hit the valve.
    Quote Originally Posted by graphicdesigner80 View Post
    dynodon64 & gmatt -
    Wow I’m interested in why this could happen. You said you turned motor over by hand right? You didn’t notice any strange binding? Compression build? I have seen before the pushrod not seated properly in the middle and possibly once you get the motor running you have a whole lot more lift and the lifters aren’t forgiving when they are primed. I don’t think it’s a cam issue. 1.7”s don’t do that with a stock cam. At the same time you would notice less oil pressure.
    Or 2nd guess. Wrong timing set up. Don’t flame me but make sure #1 piston is correct not like chevy right... if your setting timing up on the wrong side you just opened valves at the wronnnggg time...
    Locked in for further details
    I think hint #1 was the valve train noise.
    There is another side to this coin...
    Which rockers? Assuming stud-mount (adjustable) rockers... what was/is your sequence? The procedure I use is: mark the balancer at zero/TDC, at 180/BDC, and then the two 90-degree locations between TDC and BDC. Then with the crankshaft at #1 TDC on it's compression stroke, adjust #1's rockers - rotate crankshaft clockwise 90-degrees, adjust for the next cylinder in the firing order - rinse and repeat until all are done... which is really only best for starters, because the actual best way to adjust rockers (lifter preload) for a hydraulic cam setup is to adjust them with the engine running and warmed up. If you did somehow happen to mess up with your sequence of statically adjusting for the lifters' preload, each not being on camshaft lobe base circles, you would not end up with too much preload or binding in the valve train WHEN AT camshaft lobe base circles, but with valve train slop when at the base circles, and less overall valve lift... see first sentence. There's great possibility of push rods getting bent if they're jumping around with slack in the system.
    Quote Originally Posted by 82MoreDoorFox View Post
    No flaming at all! I'm second guessing myself on everything at this point. Set a lot of ford valves successfully, never chevrolet, so hopefully didn't resort to that! #1 is always passenger front! lol.
    The motor ran but sounded like an old solid-lifter 'ticky' motor. It's very possible that the sequence was done incorrectly.
    I put in two good pushrods on #1 and set lash correctly. Pulled all the spark plugs and spun the motor over by hand a dozen times watching and feeling for anything strange. No binding. Pushrods stayed dead-centered in their guides and in the holes in the head. Could hear and feel compression.
    I don't recall what sequence everything was set initially (been 11 years). Just to be totally sure, I pulled the intake to see if all the lifters are up against their snap-rings. All of them are up and feel about the same (no oil pressure). I've already purchased 8 new pushrods. Will go ahead and reset lash per the shop manual and rotate everything by hand and watch and feel for issues. Then go to rotating with the starter. Then run a compression test.
    Having the intake off will make adjustment easier and will be make it less likely to screw up something.
    Maybe I'll get lucky here.
    Thanks to everyone for the helpful suggestions. I'll have an update sometime this weekend.
    The rockers are Ford SVO 1.72 rollers on pedestal stud-mounts. Can't remember how I did the initial setup. Been over a decade.
    Not the best pic, but gives you an idea.
    I think you're onto something here. I agree that this is probably what happened here.
    That solid lifter noise you're hearing is the valves kissing the pistons.
    Quote Originally Posted by gt pony View Post
    Guess i'll find out when i do the compression test.
    May 2016
    Lake City Pa 16423
    Spring coil bind is a possibility. Do the GT40 heads springs support the lift you have? Since all 8 intake pushrods were bent, it's due to the lift being too much for piston to valve clearance, spring coil bind or rocker arms not having enough clearance to rotate through it's arc. Are there any marks on the rockers in the pivot slot or are they hitting the spring retainers behind the roller tip? You have a bind going on somewhere due to the lift in your set up.
    Good question. I'm still digging through my old receipts to see if i can find the spring rate #'s.
    No marks on rocker pivot. The only marks are on the bent rods where they rubbed the passage inside the head after they bent.
    If you were me, would you just go back to 1.6's? I'd really rather have the stock ratio since 1.7's aren't benefiting me much at all with a stock cam anyway. That and i'd rather run stock valve covers with oil baffles intact.
    May 2014
    Royal oak Mi
    I think it's your valve lash sequence is why the p rods bent . Also 1.6 of the 1.7s would hit your stock valve cover oil baffle either way..so you may need valve cover spacers ..speedway motors sell these and I'm currently using them on my stock looking build
    Whether the 1.7 s are too much or not I can't comment on because of so many other dimensions required for that you want approx .08 thousandths clearance for piston to valve clearance
    I agree with what you hear as far as the ticky noise is valves and Pistons touching
    It's running "rough" because your lash is holding valves open and hit piston and bends p rods as possibility
    May 2014
    Royal oak Mi
    Your poly nut in center and your trunnions appear correct orientation make sure you don't mix that up but looks like your good to go there in your pic
    Sounds like after it was running you swapped cams and it sat for years
    Not until you dropped it in and you experience valve train noises and running rough
    Most likely your intake valves were over tightened (hanging valves open no compression runs rough and bad noises )and this is why all 8 are bent (lash sequence is off)
    Pushrods come in .05 thousandths increments so unless your doing something really exotic or your block and heads and gasket are trick I don't see pushrods being really far off dimensionally from that cam to the other cam to bend them anyway but over revving (valve float ) hanging valves open and same scenario as overtightening or clearance (the cam swap would need pushrod length checked don't misunderstand this) but .512 -.444 and p rods come in .05 increments and that's a static number.. there's duration (how long valves stay open) but you said you dot to dot the timing and your not doing exotic things by then he sounds of it
    So dot to dot and it ran fine before the cam swap and you put it in new project and flipped the key and all the fun starts
    If your off on the start of your valve lash starting poInt they will be off x 8
    Runs rough because (8 valves are open at or near idle) because not on base circle and lashed down
    Pistons says hi to valves and your pushrods luckily are hollow and light duty thin wall for this application and absorbs the bind
    By bending
    I personally would do compression test per cylinder to make sure valves are seating and maybe put a video scope down through spark plug hole just to check to see if piston material is floating around (I phone has a scope that works great for this) and doubles up for house projects like behind walls
    Then I would get stock length hardened pushrods and really inspect your roller rockers that they spin freely the needle bearings could get knarled up when pushrods bend .i know this and so do roller lifter wheels the axle I think tweaks abit and makes the roller lifter wheel roll like a square wheel (unlikely but happened to me )
    Everything I said above is near free just good visual double checks
    i know my buddies car had a very potent 306 with 1.6 on the intake and 1.7 on the exhaust with trick flow stage 1 cam thats a animal (aftermarket Pistons
    Coil bind can be checked by rolling engine over by hand max lift and feeler gauge between coil.. make sure you check inner spring or inner damper as well per your application
    Hope your inspection turns out good
    FEP Member Mgino757's Avatar
    Jan 2011
    Virginia Beach, VA
    I second in putting 1.6's on the intake and 1.7's on the exhaust. 1.72:1 is too high in my opinion. Especially with 86 flat top pistons.
    Not to derail the thread...... all things being equal on a completely stock 1986 HO motor, many of the magazines of the day suggested you could run no mor than 0.4995 lift without having great concern from P/V clearance. Switch to a non-86 head and those numbers drop even more. E7's worked with a 1.6:1 but some found valves would hit with a 1.7x and mcparts replacement head gaskets and an HO cam. IMO they had shaved E7's and didn't know it or something strange was going on, but that's a topic for another day.
    The cam of the day before MAF came out was the B302. It had the same lift/duration specs as the B303, so around 224 degrees of duration but the LSA 116 to avoid completely pissing off the SD ECU. For the most part it worked, but the gains were not huge. With a 1.6:1 rocker lift went to 0.480. Pair it with a 1.7:1 rocker and an 86 HO motor you had certain death without valve reliefs if internals were all stock .... lift ended up at 0.510 -- well past the 0.4995 "pressing your luck" limit.
    With a stock HO cam duration at 0.050 is advertised as 210. That increases with a rocker ratio change a bit -- not sure if it was ever really measured but it should end up somewhere around 216-218 if I remember the lobe profile detail on the stock cam correctly.
    So stock HO cam the lift numbers stayed under the limit and with the exception of just a few degrees less duration you were nearly identical to the B302 if you were brave enough to use a 1.72 rocker.
    1.6 switched to 1.7: 0.444 --> 0.47175
    1.6 switched to 1.72: 0.444 --> 0.4773
    So we've touched on gasket thickness, head's machining state, cam duration and lift, how rocker ratio impacts that, etc.
    we didn't talk about cam degree-ing. Those can change how soon events happen and also impact this discussion big. Advancing a cam can quickly take up all the room you had, for example.
    The last thing on the list of stuff that matters HUGE in this discussion is intake valve diameter and intake valve centerline. For instance, the Trick Flow Twisted Wedge head rotates the intake valve and you can run one hell of a lot more lift than factory with an 86 piston without notches and never had P/V interference issues.
    May 2014
    Royal oak Mi
    All good info above.. well stated
    I understood this engine as aftermarket Pistons (.03) over it's a 306 with F cam just happens to be in a 1986 project.. not a stock 1986 short block factory Pistons per his first post second paragraph which happens to be going into another project maybe a 1982
    Also he's going down in lift using factory cam (guessing) and less duration again (guessing)than the f cam so should give additional clearance is where my head is at
    And sounds like it's dot to dot or not advanced or retard per same paragraph
    Interesting info on b302 cam and the other with it
    Good stuff
    May 2016
    Lake City Pa 16423
    In order to bend pushrods, you need something to bottom out. Either the springs are coil binding, or the rockers are hitting the studs and not allowing the full lift to be reached.
    If you have piston to valve contact, that would most likely bend the valves and not the pushrods.
    This looks like a rocker arm not getting to full travel.
