Results 1 to 13 of 13
    Default Greetings from Germany
    Hello,
    my name is Max and like the title says, I live in Germany.
    I came across this forum while searching for information on Holley 4180s since the availability of information is scarce, particularly here in Germany.
    I happen to have two Mustang 4180s sitting on top of a Blue Thunder 2x4 Intake on a 91 5.0 HO with AFR heads.
    I'm looking forward to reading and participating here.
    Toodles
    M
    Greetz!
    The Vac Seconday 4180C is full of a labyrinth of air controlled passages and emissions workarounds, with many changes over the old 4150 660 Center Squirter R- 4224s which work right out of the box.
    The 4180C is the last carb to operate in a Dual Quad Install. If you want to, join WalkingTall's carb website, and search and discuss his 4180C posts. He has access to true professional carb rebuilders through his years if experience in dealing with these carbs. These guys talk carbs day and night, and compare notes, and race car engineer.The depth of Carb knowledge is huge.
    Go to member list, WalkingTall, and read his 4180C post. Its not just Mike (WT's real name), there are 10 other regular reall Holley 4bbl experts who regularly weigh in to the Holley carb knowledge base here, and they frequent other forums as well. Ive copied there posts, and they end up reading there own stuff here...
    Welcome again.
    Hi,
    thanks for the info. I will do that and contact Mike (WalkingTall). How do I get to his website? Thanks for the help.
    Toodles
    Max
    Howdy & welcome from Texas, Max.
    Walking Tall's site: http://carb-rebuilds-plus.boards.net/
    '84.5 GT vert / roller 5 liter 4v / t5
    '86 LX coupe / 331 / t5
    '86 F-150 - 5 liter / efi / aod
    '56 F-100 - 272 y-block / 3 on the tree
    Thank you very much
    Quote Originally Posted by OttosMops View Post
    I live in Germany.M
    Servus, dto.
    1984 Ford Mustang Anniversary
    1983 Ford Capri V8 Conversion
    1985 Ford Granada Station V8 Conversion
    1993 Ford Sierra Cosworth 4WD Limited Edition
    1991 Ford Sierra Station 2.9 Cosworth 4WD Restomod
    Ja moin!
    So klein ist die Welt! Hast du auf deinem 84er Anniversary Mustang auch einen Holley 4180 sitzen?
    Gruß aus dem für dich Norden Deutschlands ;-)
    Max
    Ich hatte den 4180 auf Granada und GT350, wird bei beiden durch EFI ersetzt.
    Ah cool. Du hast nicht zufällig noch einen 4180 übrig? ;-)
    LG aus Münster
    Max
    FEP Power Member craigerSS's Avatar
    nova scotia
    Welcome aboard and hello from Canada
    here's to the freakin' weekend,I'll drink to that
    Greetings and welcome. Any pictures?
    Jun 2016
    Saint Clair MI 48079
    Hello!!! Welcome!
    Thanks guys!
    I will see what pictures I can find and if I don’t find any, I will take a few.
